I’ll keep itThanks for the review. Can you please keep that £400 or so Denon machine to hand for future testing should your techniques evolve?
Okay, but the modern gear that @amirm does normally test (with often 120 dB + SINAD!)……
Amir’s measurements without any A-weighting or so are simply more strictly. And the weighting suggestions of the DIN guys or the AES guys may change from decade to decade. So let’s keep the unweighted measurements because these are the RAW stuff. Weightend - let’s see it as an addition!
Amir is using CCIR-2k for his Dynamic range measurements. It's the same, but zeroed at 2kHz instead of 1kHz. That means a "gain" approx. 5.6dB lower compared to CCIR-1k.The CCIR 468 standard mandates a weighting curve that, contrary to A-weighting, actually provides a gain of up to 12+ dB
Is this the reason why the Parasound DAC-1100 HD of my friend Peter (from 1999 or so) wins any (nonscientific) blind shoutout against the modern Chinese DACs?I think it's a bit more complicated than that.
The CCIR 468 standard mandates a weighting curve that, contrary to A-weighting, actually provides a gain of up to 12+ dB in a bandwidth which have been found to be critical for the subjective annoyance of noise:
And the standard also mandates the use of a special detector circuit (the electronic circuit which convert the instantaneous noise voltage to average values to be used for computing the displayed noise voltage) which has characteristics designed to give a certain weight to noise spikes inside very high crest factor average signal contents.
As a result, if "simple" A-weighting applied to RMS noise level measurements usually produces more impressive figures (say a 95 dB unweighted signal to noise ratio over a 20 Hz - 20 kHz bandwidth becomes 101 dBA), CCIR 468 actually produces less high figures (say the same 95 dB becomes something as 87 dBqps, dBqps being the metrics used to show CCIR weighted noise measurements).
For specific purposes, the CCIR 468 standard also specified an unweighted measurement, using the same special detector circuit, which has a flat frequency response from 22.4 Hz to 22.4 kHz.
This standard has not been amended since several decades : it is a very well-established method of noise measurement.
I have at my disposal a Rohde & Schwarz psophometer which incorporates both CCIR compliant circuits and flat band-limited RMS noise measurement circuits. It is very enlightening to measure and compare the noise levels of various devices obtained with both methods.
By the way, I think the CCIR noise measurement standard shows in itself why noise-shaped dither can be interesting to improve the subjective performances of a digital chain in certain conditions.
Thank you! I saw Multitone from @pkane offers the possibility to save a WAV file of a 16bits/44.1kHz JTest. So if it’s better than the one of REW, it will be it.You may easily create this kind of signal with Sox.
I'll post how here later today.
First read:
Following post from user @miero on ASR explains how to play a J-Test signal with sox
Right. If they had ordered the tray-load drive then they could have put the holes in the lugs and it would all make sense.Nice measurements, but the Industrial design is very strange. It's as if they were halfway through designing a rack mount chassis and then someone pointed out it was a top loader...
I hear you. Personally I won't use any less than 7 blades on my shavers (joking) hehThank you very much for your effort! This test shows, that perfection was available at least two decades ago. We could have stopped at this point, but the show must go on. It reminds me of the ongoing "evolution" of shavers: they are beating a dead horse for decades now, but still the crowd jumps on the new 5-blade xy-shaver for a smoother shaving experience....
At the very least that's a PMD100 based DAC, which may mean an extra 6 dB of digital headroom on CD material if Parasound chose to use the chip's internal gain scaling, in addition to the standard 1 dB attenuation. I would rather look for any advantages there, especially if fed straight from a CD player (any ESS-based DAC with DPLL on basically hard-clips at 0 dBFS, although you can turn down the volume a few dB and things should straighten out). The extra dither seems to be beneficial in straightening out small-scale differential nonlinearity issues but no replacement for proper MSB trimming, apparently.Is this the reason why the Parasound DAC-1100 HD of my friend Peter (from 1999 or so) wins any (nonscientific) blind shoutout against the modern Chinese DACs?
(We did it in Cologne with bended eyes and 5 min between each session AND it was not double blind)
Now to be fair, DSD64 is about the equivalent of 18/88.
I already tested but did not publish.The next interesting part would be how the analog output fares with this. This player is using a WM8740 DAC, a relatively high-performance part in its day (DR 117 dB(A), THD+N -104 dB). You may need to resort to the -20 dBFS tone for an accurate picture as that is getting close to the Ultralite's capabilities.
You’re correct.That tells me it's a purely impedance-balanced output, i.e. one leg probably just has a resistor and coupling cap going to ground. If it's good enough for Behringer and countless other manufacturers, it was good enough for Orpheus, apparently.
Would there be a simple way for me to test that?It's a good thing it has those outputs, too, as the device is firmly IEC Class I. Hence also the absence of any mains leakage to speak of. What's a good thing in (galvanic) isolation could turn into a ground loop in a real setup though.
That's peculiar, it behaves more like a NOS player. I wonder whether there is any upsampling following digital attenuation + limiting going on in one of the socketed PLCC package ICs. (If you ever need to service this unit, I'd almost be tempted to buy a PLCC chip puller. A bit of contact cleaner may eventually be appreciated.)
Build appears neat and tidy inside with good-quality parts, very Swiss that. It's somewhat reminiscent of some entry-level test gear I've seen. Still it's not exactly impressive what you get in terms of electronics for what must have been north of $5000 at the time... I guess being made in small numbers in Switzerland did it no favors in that regard.
