Original Rega Brio-R (2012) (50 watts per channel) versus Wiim Amp Ultra (100 watts)
sads
After using just a Chromecast Audio (no external DAC) or a Justboom rPi Hat DAC (clunky) the past 10 years, I would like to improve my music streaming chain.
My initial thoughts were to buy a Wiim Ultra to replace the above, and plug into my existing Rega Brio-R (2012 model which is now a couple of generations old) which is feeding original Q Acoustic Q 3050 Floor Standing Speakers (92 dB)
I am not looking at going on a spending spree, but the thought of paying $200 more for the Wiim Amp Ultra compared to just the non-amp integrated Wiim Ultra is digestible. Would I be gaining a better amp over the Rega? (100 watts per channel versus 50 watts per channel)
At the moment my music sources are casting from a self hosted Navidrome server -> Symfonium App, or via a Yamaha CD-C600 CD player which may benefit from the Wiim DAC also.
Any thoughts appreciated.
Doubling the power gives you 3 dB higher peaks in SPL. Audibly this is not much at all, and it's only worth if you clip the Rega now and then.
Welcome to ASR,
WiiM's parent company Linkplay sells refurbished WiiM Ultra preamps with a 1-year warranty for $239 at their outlet store on Ebay. They go in and 'out of stock' regularly. AFAIK, Linkplay has not offered a refurbished WiiM Ultra Amp at this Ebay store.
Welcome to ASR,
thanks for that link, I anticipate buying a couple more of the Wiim Ultras. My opinion is an external amp is a better choice than the internal wiim amp. Most reviews say the internal amp sounds a bit thin, though I have no clue how valid that is. The specs look decent, but maybe we should see if Amir could test one and see how it measures. I would trust his assessment before I would some youtuber's assessment.
