Neutral-DAC-lover
- Joined
- Jun 20, 2026
- Messages
- 2
- Likes
- 0
I'm looking for general answers about how DAC, DSP processing occurs.
What is the typical order for a DAC/DSP in terms of processing the AA, PEQ parameters of the audio stream?
For example on a TRN Black Pearl using the cs43131, does the PEQ processing happen after the AA filter or before? Is it processed on up sampled (32b/384kHz) data or on the output stream before analog conversion?
Which has higher fidelity, the anti-aliasing digital filters? Or the PEQ processing?
If both are operated on higher sampled data, what is the advantage of the AA filter over the PEQ filter? Are they incompatible with each other or conducive together in providing the best output?
My guess is that PEQ should be applied on upsampled data, then AA applied in order to mitigate ringing effects due to down conversion.
Thank you for instructing me!
PS. Am happy to read articles, but unsure which are most relevant and where to find them.
