harry sunquist
- Joined
- Feb 17, 2021
- Messages
- 2
- Likes
- 0
Hey! Great resource, thanks, all, for supporting it. Very positive/helpful/science-based (rational objectivity seeming scarcer every day). Submitted for your consideration:
- Given I value dynamic compression and eq. for 95% of my listening, I use a Behringer DEQ-2496. (Yeah it’s old, and the analog is reputed to be crap, but I’m not aware of much else {beyond a pricey mini-dsp} that delivers comparable utility, and also believe 24/96 is adequate for earthlings.) From my PC, this requires a usb-to-toslink/spdif optical device to feed the DEQ, then from the DEQ, toslink/spdif optical-to-DAC. Therefore, on each end of the DAC I have a Topping D10s (with Topping’s drivers), and Schiit Modi 3 (not plus). Question: which ordering would would be better, and why; Topping-DEQ-Modi or Modi-DEQ-Topping? (Finally, I do use Equalizer APO, but again, like having high-quality compression in the chain, and am not aware of anything that does system-wide compression like EqAPO does system-wide EQ.)
- Is it reasonable to believe there’s no effective utility difference between a crappy/plastic TOSlink cable and a fancy one?
