I've been trying to reach to people in these forums, and inform them that a headphone's frequency response may be different than what they hear.
Measurements are taken on a coupler built to approximate the average adult ear/ear canal. Useful for comparing two headphones on the same rig, but an average ear isn't yours, and IIRC they used only 32 people to average it.
A headphone isn't a fixed pressure source. It has an acoustic impedance of its own, and your ear is a load with its own. What reaches your eardrum is whatever survives the split between the two. Most headphones sit at the stiff end of that, meaning the diaphragm moves a roughly fixed amount of air and the pressure you get depends on what it's moving into. So the gap around your ear, how the pad sits on your jaw, whether you wear glasses, your canal length, all of it lands in the response.
Bass is a seal problem. Leaks act as a high pass, and leak size is down to your head, not the designer. Several dB of variation between people is normal. Above 2k it's anatomy. Your canal resonance and eardrum impedance sit downstream of the headphone entirely, so nothing the headphone does can reach them.
My solution, pick low acoustic impedance headphones that are compliant with your ear canals acoustic impedance instead of fighting with it. That way the response stays consistent from one person to the next, which is what makes a rig derived target worth aiming at in the first place. Then EQ them to a target you usually enjoy. Here's how to spot low acoustic impedance headphones:
- Open back. Back volume drops out of the source impedance entirely. Best single indicator and the one with real multi-subject data behind it: open-backs run ~1.5 dB standard deviation at 20 Hz across listeners, closed-backs 5–8 dB.(can link Sean Olive's presentation on this one)
- Doesn't change when you reseat it. Impossible to determine unless you have your own measurement rig.
- Measures the same on different rigs. 711 vs 5128. If the shape survives a change of load, it's load insensitive by definition. Most informative check available.
- Large pad cavity. Doubling the volume halves the source impedance. Strongest structural lever in the bass.
- Vented. A deliberate leak swamps the one your jaw and glasses make, so the bass corner is set by the designer. Bass only, does nothing above a few hundred Hz.
- Bass that rolls off early. Counterintuitive. Flat to 20 Hz on a rig means it needs a perfect seal to get there. A rolloff means the corner is intentional. (May not apply to all headpones)
- Large drivers. Referred impedance scales with 1/area², so this is a strong lever, but a big driver in a shallow cup eats the pad cavity and works against the item above.
- Low resonance frequency(where impedance curve peaks), low impedance peak height. Indicates a compliant, well-damped system. Only readable on dynamics: planars usually have flat electrical impedance with no visible peak, so the sign is missing on the class that's usually lowest impedance anyway.
- Angled or recessed driver, visible mesh in the front cavity. Broader illumination of the pinna, lower-Q modes. Weak signals but they point the right way.
