jsherman999
- Joined
- Jun 24, 2026
- Messages
- 4
- Likes
- 0
I use frontier LLM for coding, this is Opus's take on a real question I had, looks correct to me but thought I should bounce it off this forum?
Prompt:
"I'm trying to map the performance+cost of current class-D amplifiers like those based around the Texas Instruments TPA3255, for example the WiiM Amp, to past Hi-fi stereo systems. In particular I'd like to know what stereo systems from the mid 1970s would match it in performance, and find out how much they would cost in adjusted dollars. The WiiM Amp can be found in this ASR SINAD chart. SINAD values relate to historical THD like: -SINAD = THD+N https://www.audiosciencereview.com/...-d-monobloc-amplifier-review-2023-png.257210/"
Answer:
I'll work through this in pieces. Let me start by getting the actual specs.I have enough on the WiiM specs. Let me get inflation-adjustment figures and a couple of 1970s reference points.I have what I need. Here's the analysis.
Here's the catch: no mid-1970s consumer amplifier could match that, because nothing in that era was built to those numbers and most measurement gear couldn't even verify them. A typical good 1975 receiver was spec'd at 0.1–0.5% THD; the genuinely excellent ones reached ~0.05% (≈66 dB SINAD); the absolute statement pieces of the late-'70s "THD wars" got to ~0.02–0.03% (≈70–74 dB SINAD). So you're looking for amplifiers that came up 15–25 dB short of the WiiM and cost vastly more.
That gap is the actual story. Class-D + modern feedback didn't just match the 1970s — it leapfrogged the best of it at a tenth of the price.
(Note the forum anecdote in my sources is consistent with this: someone spent about $320 plus tax on a Yamaha CR-420 in 1978 or 1979 — a mid-tier receiver — which is ~$1,600 today for performance well below the WiiM.)
The cleanest single answer: a Pioneer SX-1250 or Sansui AU-9900-class unit is the spiritual match — the "I want it quiet and powerful" flagship of its day — and it would run you $4,000–5,000 in today's dollars while still measuring ~20 dB worse than the $299 WiiM on SINAD (though with far more raw 8-ohm power).
Want me to push to a specific target — e.g. find the cheapest 1970s amp that broke ~70 dB SINAD (the late-'70s THD-war pieces like the Technics SU-V or Sony TA-N88), or build this into a proper SINAD-vs-inflation-adjusted-cost scatter plot?
Prompt:
Answer:
The framing problem first
The translation you proposed (-SINAD = THD+N) is right, but it hides a trap that's central to your question. The WiiM Amp measures ~89 dB SINAD at 5W (PFFB-less original) — that's about 0.0036% THD+N. The Pro/Ultra hit ~100 dB (~0.001%).Here's the catch: no mid-1970s consumer amplifier could match that, because nothing in that era was built to those numbers and most measurement gear couldn't even verify them. A typical good 1975 receiver was spec'd at 0.1–0.5% THD; the genuinely excellent ones reached ~0.05% (≈66 dB SINAD); the absolute statement pieces of the late-'70s "THD wars" got to ~0.02–0.03% (≈70–74 dB SINAD). So you're looking for amplifiers that came up 15–25 dB short of the WiiM and cost vastly more.
So the question becomes "what did 1970s money buy you in approach to this performance"
Using the CPI factor of ~6.0× (1975→2025; $100 in 1975 ≈ $597 today), here's the mapping. The WiiM Amp is ~$299, ~60W/8Ω, ~89 dB SINAD.| 1970s contender | Era spec (THD) | ≈SINAD | ~Power | 1970s price | ≈2025 $ |
| Pioneer SX-1250 (1976) | ~0.05% | ~66 dB | 160W/ch | ~$900 | ~$5,000 |
| Marantz 2270 (1971) | ~0.1% | ~60 dB | 70W/ch | ~$600 | ~$4,000+ |
| Sansui AU-9900 (1974) | ~0.05% | ~66 dB | 90W/ch | ~$650 | ~$3,900 |
| Yamaha CA-1000 (1973) | ~0.05% | ~66 dB | 70W/ch | ~$600 | ~$3,600 |
| Technics SU-9070 + SE-9060 | ~0.05% | ~66 dB | 60W/ch | ~$700 | ~$4,200 |
The one caveat that matters for fairness
SINAD is a single-tone bench number. The WiiM's weaknesses — load-dependent frequency response without PFFB, power-supply-limited dynamic burst behavior, and the ~25W loss under multitone stress noted in testing — are exactly the areas where a big 1970s linear amp with a massive transformer would feel more effortless into a difficult speaker. So "performance" splits: the WiiM wins distortion/noise by a mile and by 15× on price; the vintage flagships win on into-the-load brute authority.Want me to push to a specific target — e.g. find the cheapest 1970s amp that broke ~70 dB SINAD (the late-'70s THD-war pieces like the Technics SU-V or Sony TA-N88), or build this into a proper SINAD-vs-inflation-adjusted-cost scatter plot?
