Optimal distance to nearfield monitors?
spankjam
Howdy fellas,
Is there a proven method to calculate the optimal distance to a pair of nearfield monitors based on woofer and tweeter size? Let's say 1" and 6.5"?
Howdy fellas,
Hello,
No.
It's depends the room's acoustic, the speaker, the spl max required and all serious brands give indications on the distance
My KH420 three way 10" can be listen at 1.5 m.
My K+H O300 three way 8" can be listen at 0.75 m
Point if nearfields is the close distance to affect the room as small as possible unless there is obviously a wall very closely by.
I know you can't do this by math since speakers based on drivers react differently but i thought whether there is some scientific base math.
Hello,
No.
I think the driver layout also has an effect on the minimum distance. Monitors where the distance between the mid/woofer and the tweeter is minimised will allow for them to be used closer to the listener.
Looking at Genelecs chart, you can see that their coaxial driver models allow for closer listening distances:
It looks as though most 2 way monitors will work down to around 1 metre, but you need more space for the big 3 ways, likely due to the increased distance between the tweeter and woofer.
http://www.ohl.to/calculators/targetcurve.php but the reverberation time in a small room is irrelevant.
