There has to be a reason why higher priced cable are still well rated and the companies are still in business.
Yes indeed there is, but it has nothing to do with performance in this application.
Works perfect is a relative terminology. 1 long line will look short if you draw a longer line beside it. Please, this wasn't the whole idea for discussing here. I wouldn't encourage this anymore.Then go to Ace. That's where I got the long optical cable I use in my main system. Under $10, works perfectly
I totally get what you trying to convey but aren't people in this audio science society above all this homedepot and amazon basic stuff?
Homedepot markup there prices by 85% of the cost they purchase at, to account for shipping, handling, employees salary, damage and returns. Imaging the $10 cable was originally $1.5 and even the manufacturers make atleast 60% margin on them.
Digital signals are 1s and 0s...that’s it, binary data. I’ve been using the same el cheapo toslink cables I bought in a clearance bin 12 years ago. Handles 24/96 from a Squeezebox Touch flawlessly in 6 foot run. Spend your money on music.
On 1s and 0s, read @amirm ’s review of a USB cable:
But... when the circuitry and transmission (interfaces and conductors) are well designed and suited for their task the 1's and 0's should be perfectly recoverable within specified parameters.
svart-hvitt, not sure of your point but I find little in that thread that pertains to an optical cable. USB cables carry power and are subject to interference; optical cables are not, provided you don't bend them past their breaking point. different animal.
$?Spot the difference:
Actually three : length, price and thickness.
I just buy my cables from Monoprice. So far so good and I have a 25’ plastic optical going from tv through the tube to receiver that works perfectly and only cost a few bucks.
I've got an 8 metre toslink cable from my computer to my pre-amp. Cost under £10. Bit perfect as well (if one believes the DTS bit perfect test).Twenty Five feet? Dang, that’s a long run.
