OPPO BDP-95 Review (Blu-ray/DVD/SACD/CD Player)
Rate this CD Player
  • Terrible (*)
    Votes: 0 0.0%
  • Mediocre (**)
    Votes: 1 0.6%
  • Good (***)
    Votes: 11 6.4%
  • Excellent (****)
    Votes: 161 93.1%
I have read the manual and I think I know the answer, but just in case... When using just stereo output via XLR, will DSD play from a SACD without being converted to PCM?
Also, is there any conversion from DSD multichannel to stereo downmix?
Even if I'm "limited" to 24/96 by my miniDSP SHD I'd like to know if this is feasible.
I found a used 103 for $85 USD with the remote and manual. I think the previous owner just used it for DVDs and Pandora. :facepalm:
Despite the “3” models being lower end, it is the best sounding CD of all my players, if I use it to its internal DAC RCA out to my amp. So, like an old CD player. Coax to a newer DAC is similar too. I do wish it was a “5” though.
BTW: Padora is ad free on it. Until Pandora no longer supports the OS on it.
The OS, BR and DVD UI are, well, totally out of date!
That’s what I understood from the user manual yes and also what I saw when playing with the menu. HDMI audio output, when activated, allows to choose from "Bitstream", which means it outputs the DSD stream (Dolby, DTS, multichannel, etc…), and "LPCM" in which case it converts to PCM for the HDMI audio output (selection of downmix options to be done in another menu). It needs to set to "OFF" for the player to process DSD direct from an SACD disc via its internal DAC, to go to the analog output, and that is weird.
I guess it outputs PCM but I can’t check the HDMI digital output.
That being said, I tested the optical output with PCM 24bits, and it outputs 24bits indeed, at least up to 96kHz sample rate (I can’t test 192kHz).
What model is it?
DV 983 H
Find a deal on the bdp-95. On the device it says Stereo Out. XLR or RCA. I can connect my headphone amp to either source correct? My amp has balanced xlr and rca input.
I have a few sacd's. This unit is cheaper than some of the newer stuff i've seen.
@NTTY,
Thank you for this very thorough test and review...!!
I bought a BDP-95 I excellent condition in January this year, for the Swedish equivalent of 445 EUR / 525 USD. It brought a completely new perspective to the possible sound quality of CDs (not to mention both sound and picture quality for DVD/Blu-Ray).
But I have a question, in the "intersample-overs" test you talk about (and measure) the effect of lowering the volume by -2 dB (and even -3 dB). I wonder how much that is on the volume controls scale, 100 is full, so how much would -2 dB and -3 dB be...?
According to the manual the volume control is analog, to me that sounds as if it acts after the DAC. If so, how can lowering it increase the headroom for the oversampling interpolator. Obviously, it does, but how…? Or is there another way of lowering the volume…?
I used to have the volume set on “Fixed” and only use the amplifiers volume control. Would putting the volume on the Oppo to, say 94, and leave it there and use only the amps volume control, give me the excellent measurements at the bottom of the table…?
THANKS again…!!!!!
Micke
@NTTY,
I don't recall, unfortunately. I would think one level down is 0.5db less.
Not quite, the manual says it influences only the analog output, not the digital ones, but that doesn't imply it is post the DAC. Volume control is offered by the ESS DAC prior to conversion, and it explains the improvements seen with ISO resistance.
Yes, that's what I would do of I were you (maybe 96, since no improvement beyond -2dB).
THANKS again…!!!!!
Micke
Enjoy ;)
Thanks for this too…!!
I just assumed that since the volume control was only applied to the analog output, it was done in that domain, thanks for the added information.
About the -3 dB reduction, I derived that from your comment “Decreasing the volume by one more dB gives the same best result with 11'025 Hz test file”, I guess I might have jumped to conclusions there too… :)
Would you consider the -2 dB lowering of volume (in the digital domain) to be “overkill” for normal use, is it only valid in extreme cases OR might it be useful/audible for normal CDs, and does it affect SACDs…? I usually prefer to pass on digital signals without touching any levels, leaving that to the final (analog) stage(s), so I wonder if there might be some downside to fiddling, and if it really would be noticeable with normal discs.
And once again, THANKS, quite amazing work you've done on this, for me, highly interesting subject…!!!
Micke
You're right, that's what it means, bad memory of me, obviously.
Problem is that I did not keep any measurements with volume at -3dB to confirm. But I guess that's what I meant, indeed.
I think -2dB is not overkill, there are lots of CDA Masters going above 0dBFS. With this OPPO, there are no negative consequences when lowering the volume, so, no reason not to use.
SACD masters are different and full scale too. I did not run any test with SACD and volume down, but I think it is active too, if I understand well the ES9018 datasheet.
To conclude, I would use it ;)
Hello again,
And I’ll keep repeating – THANKS…
That means that I didn’t jump too far with the -3 dB value after all, that’s reassuring. :)
I read through the whole thread but the post you linked to (regarding SACDs and DSD) was on such a high level (and dug so deep) that I must admit I just skimmed through it. It is still on a level that is a “bit” too high for me to make any practical use of, but very interesting in combination with all the other information!
I will set the volume to 96, or maybe even 94, ;) and see if I can find information on the “scale” of the volume control somewhere, maybe also try to measure the resulting differences in output to see if I can confirm the resulting damping. I am sure you have the ES9018 facts correct and even if the volume control is not applicable to SACD/DSD, I guess it can do no harm having it turned down slightly.
I’m really glad I found this thread, your review confirmed, with measurements, what I was already hearing. It is absolutely clear that it was the right choice to buy the BDP-95 when I, by pure chance, found it for sale in a HiFi-shop nearby. I had never even heard of Oppo (!) but needed a new multi-disc player. I decided after having spent the lunch with Google.
Thanks for all the additional answers and information and a Happy New Year...!!!
Micke
Hello NTTY,
I did find some confirmation regarding the size of the steps of the volume control of the Oppo BDP-95.
According to the release notes for a firmware upgrade in 2012 –
“Provided smaller volume control adjustment steps through the Analog audio outputs. Previously the Volume Control adjusts at 5 per step in the index and 2 dB per step in the level. This firmware allows volume control at 1 per step in the index (100, 99, 98, 97, ...), 0.5 dB per step in the level for BDP-95, 1 dB per two consecutive steps in the level for BDP-93 (e.g. indexes 100 and 99 share the same volume level).”
Most likely it stayed that way in all later firmware.
And this quote from Oppo, that I found on Audiogon Forums (https://forum.audiogon.com/discussions/oppo-s-volume-control), confirms what you said about the ES9018 chip and it being safe to reduce the volume without any negative effects. The 95 and the 105 uses the same DAC-chip, so this should apply to them both –
“The BDP-105 players will not lose resolution since they are 32-bit DACs”
And I confirmed that the volume control affects the output of SACDs, at least on the Left/Right RCA outputs.
So, should you be worried about potential distortion due to hot masters, you know what to do...
Yes, and just to be safe(r), I leave the volume control at 95, :cool: this being a 0,5 dB more (or rather less) than the -2 dB that already made the BDP-95 perform the best in your comparison…
Micke :)
OPPO BDP-95 variable output level measurement.
OPPO BDP-95 Measurements (SACD)
Unfortunately, I can't create an SACD test disc, so I used the one from Denon.
To start with, when I first tested the SACD mode, I saw on the screen that it was displaying "PCM", but why? Because, and thanks to the very good documentation, if we set HDMI to output DSD data, then analog output will get a DSD to PCM digital conversion before being converted to analog. Go figure. So it is necessary to disable HDMI bitstream output to get the DSD data to be directly converted. The setup is this one (HDMI Off, SACD Output DSD, rest does not matter):
Back to the Denon Test SACD. It has some test files, and the main one is a sine tone 1kHz @-16dBSACD (=-16dBFS per Denon’s information):
The software shows 14.7bits ENOB, but since we play at -16dBFS, we need to add 16/6=2.7bits, so the true ENOB is 17.4bits, and it is dominated by distorsion. Note that I put the scale in dBFS instead of dBr, to better show the lower noise floor.
You can also see some noise shaping in audio band (that double noise-floor wave, from 2khz to 20kHz), which is the way Denon created their test file.
Let's play the same with DSD to PCM conversion before DA conversion:
Same performances but a little more low level distorsion.
And since I don't have much more to play with, I thought about an interesting comparison and, actually, this is why I have multiple -16dBFS test tones in my test CD :)
So, here is a 999.91Hz sine @-16dBFS, with shape dither, played form my test CD, not SACD:
Not so far, right? Of course, we see more shaped noise in audio band here because, as opposed to SACD, we are limited to 22kHz where to put the noise create by the noise shaper. But let's play a little more, and restrict the analysis from 20Hz to 6kHz:
What we see is that from 20Hz to 6kHz, we get the same performances from the Audio CD and the SACD. Of course this is cheating, but not so much since our ears degrade very much in performances above 6kHz, as per the CCIR-2k curve.
One more nasty/funny game? Yes, you don't ask for it, but you'll get it. Let's apply the CCIR-2k curve to the above, but this time, I let the computer include noise up to 20kHz, as usual:
The SACD wins, audiophiles are saved. But note we get "only" 1.5bit more than what can be achieved with the Audio CD and shape dither. So no, not 4 bits more as advertised by Sony (if I recall). We don't go from 16bits to 20bits, non.
What else can I say. Oh yes, I know, let's talks ultrasonic noise :cool: The below is the same 1kHz sine @-16dBFS played in native DSD mode or DSD to PCM:
Yes, the DSD native creates much more ultrasonic noise! This is because the PCM conversion comes with a digital filter of a frequency cut set at around 47kHz, so it attenuates everything beyond that point. What do you prefer?
OPPO BDP-95 Measurements (PCM 24bits - from USB drive)
Hmmn... I need a whiskey, and to turn on my old obsolete Sony R2R CD Player :cool:
Right, back to the high performing OPPO. We've not seen yet what this player is capable of. So let's use 24bits test files then...
This is the very standardized SINAD test of @amirm, that is 1kHz sine @0dBFS (4Vrms output), at 44.1kHz, with FFT length of 32k and 4 averages (3 for Amir, but I can't do only 3):
A SINAD of 116.4dB would put this player in the "excellent" range of Amir's current dashboard. That's insane for a universal video player that is 15 years old!
And now we see more of that low random noise at the foot of the fundamental. It's to be ignored though, as per the AES mandated notch applied here.
And look at the total absence of power supply related noise, with a punishing 512k FFT length:
Nothing, zip, nada, rien!!! Someone was mastering power supply at OPPO. Actually, what you see is a PS that is silent below 0.0000008%, when running a full scale sine tone, can you believe it? Me not... I could run an FFT at 4M to try to find the bottom of it. But hey, that's laboratory level!
One more time, I am nothing else but impressed.
Jitter test you ask?
Nailed!!
Final conclusion - All things considered
Do I really need to write anything? :p
What a player! What an achiever! I'm speechless but I need to put myself together.
I am very happy I got the opportunity to test this player. And I am very pleased to report crazy good measurements. This was an insane multi-format player. What a beast. And only 999$ for satellite-class player, really? Oh boy.
You, owners of this beast, you're lucky!!!
Cherish it, listen to music with it, there are no format, no master that this player will fail.
What a device...
I hope you enjoyed this review!
Thank you for such a great review! How does it compare to the 105?
Hello everyone,
This is a review and measurements of the OPPO BDP-95 Blu-Ray, DVD, SACD, CD player and transport.
It is on a kind loan from a friend who wanted to know how it performs.
Sorry for the dark image, I did not manage to do better than that.
OPPO BDP-95 - Presentation
Released in 2011 at 999$, this was a high quality universal Player. OPPO was known to deliver high-end full featured devices.
If the price was high, I am nevertheless impressed by all the features and their accompanying paid licenses to read all available media of the time.
So it will read all discs (CD, DVD, SACD, Blu-Ray), and files from USB-drive / e-SATA / Network, PCM 24 bits, DSD, with many different codecs, and including HDCD. Of course it will not read the most recent ones but offers a "bitstream" output via HDMI which might be sufficient to get it processed externally. But since I'm not an expert, by far, into these, I have to let you deep-dive.
The user manual is 93 pages long, so if you want/need to know more about this player, it's probably the best source of information. At least it was to me. There are also countless forum messages about this unit, with lots of good info and lots of crap too, as usual.
The back of the device is very busy:
Stereo audio gets luxury treatment with XLR on top of RCA. All outputs have golden connectors :cool:
You can also see what was a concern at the time: the rear fan. And yes it comes on, regularly, even when listening to a CD. We have different sensitivity to that type of noise, but on a tangible perspective, I measured it adds 1dB to background noise of my room (ITU-R 468) at 6 feet distance (from 35.9dB to 36.8dB). I could hear it well in silence, not when it was playing any music.
Besides the nice aluminum front, rest of the unit looks and feels "standard", no fancy thick material here. And so it was surprisingly heavy to me, with more than 7kg (16lbs). I thought "This one must be really full". And, well, yes!
The huge audio board (inverted) covers more than half of the player. I did not remove it because I counted 25 screws and at least two connectors to remove, so I thought unnecessary to take risks on a unit that I don't own.
It features two ESS 9018S (8 channels) DACs. One of the two is dedicated to the main stereo outputs (XLR and RCA) and so 4 DAC channels and paralleled for left and right.
The picture does not necessarily provide you with the perception of built quality that I got when looking at it. We can still see and guess that the physical architecture is well thought. The linear power supply is based on a nice custom design transformer from Rotel (who indeed had that expertise and capability from factory), and behind it, the entirely enclosed main PSU (for video, I guess). In the middle we get the drive, entirely protected too, and on its right, the dedicated PSU for the big audio board.
You will find plenty of additional pictures on the web, from a simple search, should you want to know/see more.
User experience
I usually don't talk much about using a device. But this is one is much more complex than the "standard" CD Players I'm used to review. So here is my feedback:
  • It's mandatory to use an external display, at minimum for the initial setup. Once correctly setup, you can use it to play SACD or CD without needing a screen.
  • The front display is big enough to be seen from a distance, but some information (such as DSD or PCM play) can only be seen when very close to it.
  • The front buttons are painful to use. They are touch sensitive but don't confirm they received an order. I used the remote control as a consequence.
  • Some audio options (eg HDCD ON/OFF) will be configurable only if there are no discs in the player.
  • It is necessary to read the very long user guide to get to understand how to tune this player, but that's also because of so many functions.
  • The drive is slow to load a disc because it will identify in its memory where the previous play stopped. Unnecessary with an audio CD but it wants to do it, and so we have to wait 11sec after the disc is loaded.
  • FFW and REW are painful as with all video players. Skipping a track is reasonably fast, but not equivalent to a dedicated CD Player.
  • It is gapless playback!
OPPO BDP-95 - Measurements
Unlike my other reviews, I will need to split my review into more sections since there are so many possibilities with this Player.
The performances are nearly the same from RCA and XLR analog outputs, I will report only from XLR, which BTW output 4Vrms compared to 2Vrms for RCA. Besides that, I will review as below:
  • CD Audio (including drive test and digital output)
  • SACD
  • USB drive (24bits - including digital output)
This is very likely to be my longest review to date. Let's go?
All measurements performed with an E1DA Cosmos ADCiso (grade O), and the Cosmos Scaler (100kohms from unbalanced input) for analog outputs, and a Motu UltraLite Mk5 for digital.
OPPO BDP-95 - Measurements (CD Audio - XLR)
I am now consistent with my specific measurements for CD Players, as I described them in the post “More than we hear”, and as I reported them for the Onkyo C-733 review. Over time, this will help comparing the devices I reviewed.
The balanced outputs (4Vrms) are non-inverting but phase can be inverted from the on-screen menu. The two channels imbalance was a low 0.02dB (very good).
As usual, let's start with my standard 999.91Hz sine @0dBFS (without dither) from the Test CD (RCA out):
This is state of the art for CD Audio. Even at full scale, the OPPO has no issue to reach max theoretical SNR (unweighted) of the format. The distorsion is extremely low (-125dBr) and one spike can be at 3kHz only because I use 512k FTT length.
Let's try the same 6dB lower:
Master class again. The few spikes you see come from the quantization errors, not from the converter. This is because it is undithered signal, and that generates some concentration of rounding (quantization) errors. As a matter of facts, below is the WAV file analyzed directly from the computer:
As you can appreciate, it's nearly the same, and so that is impressive.
I usually have a look at any potential PS related leakage, and you saw it before, there are none, even if I zoom:
Again, the few spikes come from the digital file, quantization errors. That said, we can see very low level random noise at the foot of the fundamental. We can see it again because of the lengthy FFT I use (512k), and that is below -135dBr, so I mention it for fun. It should show itself more when we go 24bits bit depth.
The above is extremely good, especially for a video player. And in that player, the video board is always on, but it obviously does not negatively impact the audio output. Very good.
Oh yes, there is a useless "Pure Audio" button that deactivates video to avoid disrupting the fragile Audio signal. Well, first, the video in not entirely stopped, it stills sends a dark screen signal to the monitor. Second, I did not measure any difference. So don't bother.
Next is the bandwidth:
This flat, only -0.15dB at 20kHz. The two channels match at 0.02dB.
And let's have a look at the job of the oversampling filter, with a wider bandwidth:
Very nice! I had to increase the vertical scale down to -170dBr to see the noise floor, out of band! The attenuation is minimum -110dB, no signs of noise shaping. This is a sharp filter fully active at 24kHz. The artifacts of the dual tones are attenuated by -120dB, best in class, again.
Please appreciate the visual near absence of intermodulation distortion. Actually the software calculate -112dBr, noise floor being the one of the Audio CD.
Let's have a look at the multitone test that a lot of you like very much, and guess what:
Yes, nailed, perfect, as much as it can be from the format. There is 0 distortion here, down to -115dB, ie near 20bits of distorsion free replay.
Oh yes, the jitter test:
Allow me not to overlay the digital output, because the one from analog output is perfection. We can see that random noise at the foot of the fundamental, again, but so low that we can truly ignore it. Again, you get to see it because I use a 512k FFT length. There is a "Master Clock" in the OPPO, and it works well.
Started with the Teac VRDS-20 review, and on your request + support to get it done (more here), I'm adding now an "intersample-overs" test which intends to identify the behavior of the digital filtering and DAC when it come to process near clipping signals. Because of the oversampling, there might be interpolated data that go above 0dBFS and would saturate (clip) the DAC and therefore the output. And this effect shows through distorsion (THD+N measurement up to 96kHz):
Intersample-overs tests
Bandwidth of the THD+N measurements is 20Hz - 96kHz
5512.5 Hz sine,
Peak = +0.69dBFS
7350 Hz sine,
Peak = +1.25dBFS
11025 Hz sine,
Peak = +3.0dBFS
Teac VRDS-20-30.7dB-26.6dB-17.6dB
Yamaha CD-1-84.6dB-84.9dB-78.1dB
Denon DCD-900NE-34.2dB-27.1dB-19.1dB
Denon DCD-SA1-33.6dB-27.6dB-18.3dB
Onkyo C-733-88.3dB-40.4dB-21.2dB
Denon DCD-3560-30.2dB-24.7dB-17.4dB
Myryad Z210-70.6dB (noise dominated)-71.1dB (noise dominated)-29.4dB (H3 dominated)
Sony CDP-X333ES-30.5dB-24.8dB-16.3dB
BARCO-EMT 982-32.7dB-24.5dB-16.3dB
TASCAM CD-200-73.5dB-36.3dB-19.7dB
Sony CDP-597-30.4dB-24.7dB-16.5dB
SMSL PL100-53.1dB-31dB-19.1dB
OPPO BDP-95-39dB-28.8dB-19.2dB
OPPO BDP-95 (vol -2dB)-95dB-97.5dB-32.7dB
Basically, the oversampling interpolator does not have any headroom. But this player has volume control too. And look, if I reduce the volume by 2dB, then I get the best results so far, all dominated by digital noise due to the limit of the 16bits bit depth. Decreasing the volume by one more dB gives the same best result with 11'025Hz test file.
Now, you might wonder if decreasing by 2dB the volume decreases the overall performance by the same. Actually not:
Even being very unfriendly, and letting the computer include all noise up to 91kHz, I still get my full 16bits resolution and no distortion. The SNR is still above 98dB. What a DAC! Well, yes it's an ESS, we know... but so well implemented here.
Let's continue with the good old 3DC measurement that Stereophile was often using as a proof of low noise DAC. It is from an undithered 997Hz sine at -90.31dBFS. With 16bits, the signal should appear (on a scope) as the 3DC levels of the smallest symmetrical sign magnitude digital signal:
Haha, I thought I made a mistake, thinking I captured the digital output of the player. No no, this is the analog one! It is, to date, the best trace I've seen. There's nearly 0 noise added to this most fragile 16bits signal. The linearity is of course perfect. State of the art that so many recent dedicated CD players do not achieve...
Other measurements (not shown):
  • IMD AES-17 DFD "Analog" (18kHz & 20kHz 1:1) : -112.3dB
  • IMD AES-17 DFD "Digital" (17'987Hz & 19'997Hz 1:1) : -121.6dB
  • IMD AES-17 MD (41Hz & 7993Hz 4:1): -119.2dB
  • IMD DIN (250Hz & 8kHz 4:1) : -108.3dB
  • IMD CCIF (19kHz & 20kHz 1:1) : -119.7dB
  • IMD SMPTE (60Hz & 7kHz 1:4) : -106.1dB
  • IMD TDFD Bass (41Hz & 89Hz 1:1) : -120.3dB
  • IMD TDFD (13'58Hz & 19841Hz 1:1) : -133.8dB
  • Dynamic Range : 98.9dB (without dither @-60dBFS)
  • Crosstalk: 100Hh (below -135dBr), 1kHz (-125dBr), 10kHz (-103.7dBr)
  • Pitch Error : 19'997.08Hz (19'997Hz requested) ie 4ppm
  • Gapless playback : Yes
The IMD scores are best in class.
The Dynamic range is the best that can be measured (unweighted) with the Audio CD.
A very small crosstalk can be seen, I was almost disappointed considering the crazy good other results :)
Pitch error is a very small 4ppm.
Last and not least, I like to run a THD vs Frequency sweep at -12dBFS as it shows how the conversion has evolved over time. I am currently using the beta version of REW and I discovered that this sweep gives better and more reliable results than before. I did not overlay with other CD players, because it's the best trace I got, again, and actually it is the same if I run the test from the digital output:
One more time, I'm measuring the digital content, as if there was no DA conversion. I love it!
As I did with the Sony CDP-597, I add a "max DAC resolution" measurement test. It is performed from a 999.91Hz sine @-12dBFS with shape dither (from Audacity). I restrict the THD+N span to 20Hz - 6kHz in REW not to account for the noise of the shape dither beyond 6kHz. I take the calculated ENOB and simply add 2bits to it (due to the -12dB attenuation, as 1bits=6dB). The potential maximum, when calculated from the digital WAV file, is 18.7bits under this test. A "transparent" DAC should achieve 18.7bits, ie 100% in this test.
Here are the results compared to others:
CD Player model or DACCalculated ENOB (999.91Hz sine @-12dBFS with shape dither, THD+N span = 20Hz - 6kHz)Percentage of max resolution achieved (higher is better)
OPPO BDP-9518.7bits100%
SMSL PS-200 (from CD player)18.6bits99.47%
Denon DCD-900NE18.5bits98.93%
Onkyo C-73318bits96.26%
SMSL PL15018bits96.26%
SMSL PL10017.9bits95.72%
Sony CDP-59717.5bits93.58%
Onkyo DX-735517.3bits92.51%
Denon DCD-356017.2bits91.98%
Yamaha CD-S30316.8bits89.84%
Accuphase DP-7016.6bits88.77%
Sony CDP-337ESD16.6bits88.77%
Teac VRDS-25x16.5bits88.24%
Marantz CD-7314.9bits79.68%
The OPPO BDP-95 forced me to reset the max expectation on this test! Oh come-on dude. When I created this test, I calculated 18.7bits from the digital file. And I truly thought no player nor DAC would achieve the same value from analog outputs. So I set the max to 18.6bits, as the reference to achieve. The SMSL PS200 did it, and I thought better would never be achieved. I was wrong. The OPPO reset this test!
As a consequence, the new max is now 18.7bits!
OPPO BDP-95 - Testing the drive
Before going to SACD and 24bits specific measurements, let me talk about the drive tracking capabilities, since these tests are performed from a CD Audio.
What would be good measurements if the drive would not properly read a slightly scratched CD, or one that was created at the limits of the norm? The below tests reply to these questions.
The OPPO took 11 seconds to read the TOC of my 40 tracks test CD, and this is mainly because it will position itself precisely where it previously stopped it.
Here are the results:
Test typeTechnical testResults
Variation of linear cutting velocityFrom 1.20m/s to 1.40m/sPass
Variation of track pitchFrom 1.5µm to 1.7µmPass
Combined variations of track pitch and velocityFrom 1.20m/s & 1.5µm to 1.40m/s & 1.7µmPass
HF detection (asymmetry pitch/flat ratio)Variation from 2% to 18%Pass
Dropouts resistanceFrom 0.05mm (0.038ms) to 4mm (3.080ms)Pass
Combined dropouts and smallest pitchFrom 1.5µm & 1mm to 1.5µm & 2.4mmPass
Successive dropoutsFrom 2x0.1mm to 2x3mmPass
If you're not bored by me repeating myself... Guess what? Best in class!
The OPPO repeats the excellence of the TASCAM CD-200. It reads a disc with holes drilled into it, even if they are successive! I could measure the interpolation kicking off at 2.4mm, which I think is what is expected from the Redbook, but I very rarely see that performance from a drive.
What a CD player!
OPPO BDP-95 - Digital Output (from Audio CD)
Ok, so it's a perfect CD player. Nothing more can be expected from an external DAC. But let's verify if it outputs a "perfect" digital stream. And, from my standard 999.91Hz @0dBFS file...:
Noooooo! What the heck is that distortion! Well, at 1 dB lower, it looks familiar:
This one, I know very well. It is the typical distorsion created by Windows Media Player when burning a CD with the option "Adjust Levels" set to ON. Microsoft... new owners of the HDCD license... hmmm... Let me turn off the HDCD replay...
Bingo, MSFT strikes again, my guess. Why on earth do we have HDCD decoding generating distorsion on 16bits PCM at the digital output?
My 3DC test was affected too, but I forgot to do a screenshot, so you get only the one with HDCD off:
It is perfect.
With HDCD off, the bitstream is therefore "perfect". My ultimate proof is when I reuse the intersample overs test at 5512.50Hz, with a phase shift of 67.5°, like I did for the TASCAM CD-200 review. This signal generates an overshoot of +0.69dB and so if the signal would be modified before being sent, it would show either a reduction of amplitude or we'd see some sort of saturation/increase noise/distorsion. So here we go, the below is a comparison between the WAV File directly processed by the PC, and when played by the OPPO via the optical out:
Same traces = perfect digital output
Partial conclusion (As a CD Player)
I nearly reached the maximum pictures per post, so I will continue in another message about SACD and PCM 24bits performances.
In the meantime, what a CD player!
It sets a precedence nearly everywhere, as per my latest refined tests! I had the feeling, so many times, to be measuring my test files directly from the WAV source. That was almost disturbing!
This is the best CD Player I had in my hands so far. Why did you stop making them OPPO?
To be continued later...
Nailed!!
What a device...
You wrote: "OPPO BDP-95 - Digital Output (from Audio CD)"
Am I missing something? I can't see Digital outputs on the back? Teh caox and opticals SPDIF are in the input section, aren't they? Would like to use the BDP-95 also as an Transport. Thinking about the SMSL P200T or Tascam CD200 (if I could find one), but with the Oppo I can get rid off my LG BluRay-Player...
SPDIF are in the output section. This item is not designed to do the job of a DAC.
No, they are digital outputs.
It's typical for digital disc players of the era—15 years ago—to only have digital outs. Note, however, that there is a slot for USB, another for "External Storage". From the Manual for the BDP-95:
"The OPPO BDP-95 Blu-Ray Disc Player has significantly improved its internet exploration capabilities
compared to its predecessors. Currently it supports both Netflix and Blockbuster for instant online media
streaming, as well as in-home network media sharing via My Network which is functionally equivalent to DLNA.
Additional network applications may be added with future firmware updates."
