I’m not sure anyone can help me with this question due to the combination of gear and the use case, but does anyone know what a good “unity gain” volume setting is for the headphone amplifier on the Oppo UDP-205?
I want to use the near-lossless Leedh volume control on the Lumin U1 Mini streamer. The Lumin threads on various forums say to set “unity gain” on your amp and then control volume on the Lumin app.
I have the Lumin U1 Mini connected to the Oppo 205 via USB DAC input and I’m using this setup as a headphone streaming rig only. I like the DAC and built-in head amp of the Oppo 205, but my cans and IEMs (Sony MDR-Z1R and IER-Z1R) are too sensitive for the powerful Oppo head amp and I have to set between 24 and 34 on the Oppo volume for my preferred listening volume. So I thought that was too much digital attenuation in the ESS DAC chips and wanted to do the better Leedh volume control in the Lumin.
My understanding of “unity gain” is not good. But I figured a start would be to set the Oppo 205 head amp’s volume to 100 and adjust the Lumin’s Leedh software volume control to 34 (my max volume level usually on the Oppo): it was a little too loud, so I adjusted the Oppo down to 97 and it sounded the same as when I don’t use the Lumin’s volume control. So Lumin digital output fixed at 100% vol with the Oppo head amp vol at 34 = Lumin Leedh Processing with digital vol at 34 and Oppo head amp at 97.
Is that approach OK? Or is this more about voltage and measurements? I’ve also read many threads where their amp’s unity gain is at “12 o‘clock” on the volume knob. Since the Oppo 205 doesn’t have a volume knob that was no help ;-)
[And by the way, the Lumin’s Leedh processing sounded better to my ears than the Oppo doing the volume control.]
Thanks in advance for any and all guidance.
Cheers,
Gus
Cheers,
Gus
