10PSPMemSticksForMiku2007
- Joined
- Aug 13, 2024
- Messages
- 114
- Likes
- 105
I've been trying many different desktop speakers and am not satisfied with any of them, so I came up with an unusual design. Attached is a crude diagram, not at all to scale, but it illustrates the idea.
I want to achieve the following - flat response from at least 40hz to 17khz with little distortion, point source or close to it, narrow radiation, excellent dynamics, good power efficiency. Despite having good bass, I don't want it to vibrate my desk. With the PC, I have 8 channels output and unlimited DSP. The desk is quite big.
I plan to make a WAW with slot-loaded woofers and a horn centered between them. It will fill the vertical space between my desk and ceiling to get more internal volume than normal desktop speakers. Each speaker is split into two sealed boxes with a common rear panel and a slot between them. Roughly 8" wide x 12" deep x 42" high or ~2.3 cubic feet for each half. In the slot, 4 12" woofers in push-pull. Each pair of will be as close as I can fit them with a compression driver + horn in the middle. The width of the slot would be about 5 or 6 inches, as small as I can make it. So each speaker is about 24" wide in total.
For me, the huge size is no problem, but it would be possible to create a much more reasonably sized version if you don't want so much output at such low frequencies.
For the CD I'm thinking of the 1.4" Eminence N314T-8. Horn is FaitalPro LTH142 60x50 tractrix which claims linear loading to 500hz. Woofers, GRS 12PT-8. Parts cost is $600 for each speaker, not counting the cabinet.
With DSP I should be able to get a flat response to 30hz at 107db at 1 meter. The crossover point and slope is completely flexible but I'm hoping around 500hz. Sitting only 1 meter away I hope I'm not torturing the CD too much by doing this. The other concern is high frequency cancellation from slot loading the woofers, especially if I need a higher crossover. Based on this thread about a slot-loaded 12" w-baffle subwoofer, it looks like it would barely work.
I'm not planning on a unity horn because I absolutely want the woofers in a force-cancelling arrangement. I'm only hoping the difference in radiation pattern does not matter so much if I can get a very low crossover.
So far, it is looking OK to me, but this will be the first time I use a compression driver or use slot-loaded woofers to such a high frequency. It would be really great to get feedback from someone experienced in these topics before I spend $1000+ on this. In that case, thank you in advance for taking the time.
