Openbox IBasso DX320 digital audio player: Is It Good Deal?
mphil
Hello all, I’m looking at an open box IBasso DX320 digital audio player priced at $900 on clearance, and I’m wondering if it’s a good deal. The DX320 is a flagship DAP known for excellent sound quality, strong processing power, and support for a wide range of high-resolution audio formats, which makes it popular with serious music listeners. Open box usually means the item was returned or used for display, but it should still work fully. Before buying, it’s important to check the condition, warranty status, and included accessories. If everything checks out and the price is significantly lower than new, it could be a solid purchase.
Thanks .
Hello all, I’m looking at an open box IBasso DX320 digital audio player priced at $900 on clearance, and I’m wondering if it’s a good deal. The DX320 is a flagship DAP known for excellent sound quality, strong processing power, and support for a wide range of high-resolution audio formats, which makes it popular with serious music listeners. Open box usually means the item was ome returned or used for display, but it should still work fully. Before buying, it’s important to check the condition, warranty status, and included accessories. If everything checks out and the price is significantly lower than new, it could be a solid purchase.
Thanks .
My issue has been solved.
Thanks .
Way overpriced. The sound quality will be the same as a $10 dongle + phone. (it may give more power, i.e. be louder, but then you could just buy a $40 dongle... with more power).
You should be able to find much cheaper DAPs that are just as good if you don't want to use your phone (e.g. you want something smaller, or with more battery).
