solderdude
I'm sure that is correct.I do not think either group is lying, exaggerating, or attempting to deceive anyone.
My working assumption is that people are reporting their experiences truthfully.
The issue is that people claiming to hear differences have no data to back up their 'findings' other than a 'trust me bro'.
Measurements usually do not lie if done correctly under similar conditions.
Also there may be differences in clipping behavior which generally is not measured but may be present during listening sessions.
Undetectable (unmeasurable as in measurement limits ? or as in not audible ?My claim is deliberately limited:
An op-amp is a system component. Replacing it changes the physical system, but the resulting effect may range from undetectable, to measurably different, to audibly different, to improved, degraded, unstable, or completely non-functional. The result belongs to the op-amp–circuit–system interaction, not to the op-amp in isolation.
Measurable different... sure the many tests we have seen of op-amps shows this.
Audibly different ? depends on the circuit, gain, function, proper operation, noise levels, clipping behavior, current limiter behavior.
Improved ... improved measurements ? BW, distortion, noise ?
degraded ... noise, distortion (clipping), BW ?
unstable ... under which conditions ?
This has all been discussed many times here.
