Without knowing what circuit ATM audio used to test these opamps there graphs are useless. The only advantage discrete OAs have is higher power output. Something thats unnecessary for audio applications. All you would have to do to make your discrete OA measure better is to increase the load in your test circuit till the IC OA starts to distort.I can hear the message. I have hoped so much for a Sparkos SS3602 test and can´t thank you enough for doing it.
There is a publication with very slight measurement differences between various expensive OP amps in the FFT Spectrum.
The problem I have is: Maybe your FFT Spectrum for the sparkos is, if you look at the k2 distortion, 5-10 dB better than the Ti5532
But your print it as two overlaying graphs, placed on top of each other so you can´t see the true k2 distortion value of the Sparkos (I can´t see where the red k2 line ends!).
Would it be possible to print the two measurements separetly (just the FFT Spectrum),
so that we would have at least a tiny tiny tiny difference between these two op amps?
Maybe the corresponding graph is still in the memory of the AP555x?
Not that I would be able to hear these differences.
One last question: Why did you not do the usual SINAD Measurements for the two versions of the Fosi V3 Mono (5 Watt, FFT up to 20 kHz)?
Ah, and here the publikation:
How would the Sparkos SS3602 OP amp perform in this 20 kHz FFT measurements in comparison to Ti5532 (SINAD etc)?
I tried to find this blog post at ATM (which are heavily into the snake oil) but couldnt find it, if anybody could provide a link I would appreciate it.
