Op-amp Rolling Using AIYIMA A07
pma
Prague
I have made my homework and re-measured AIYIMA A07 with NE5532, LME49720 and OPA2134. My measuring system has been improved since the time of my first measurements of the A07. However, no breakthrough findings, but good enough to debunk some strange myths.
I measured the A07 supplied from SMPS (Meanwell RS-100-24) set to 27Vdc output and the amplifier was loaded with 4R7/200W resistor.
Below are the results.
1. THD vs. output voltage with 3 opamps:
It can be seen that the plots are almost identical. BTW, very good result.
2. THD vs. frequency at 20W/4.7ohm @BW48kHz
Again, the plots are identical, only at very low frequencies NE5532 is lower due to its lower noise. I do not like that result very much (THD rise with frequency), however it is typical for TPA3255 class D amps measured with BW48kHz. I would like to add that the NE5532 is a better choice for AIYIMA A07 than the LME49720. The reason is that 5532 has lower input current noise than 49720. The thdfreq plot of 49720 x 5532 is similar to 2134 x 5532 plot. 2134 has higher input voltage noise than 5532. Once again, 5532 is the technical winner due its versatility. But nothing to be audible.
Next plot is THD vs. frequency measured with 90kHz bandwidth. We can see how the distortion proportionally rises with frequency, if we demask the usual trick with 20kHz BW limited THD or THD+N. However, this has nothing in common with the opamp used.
So, if we use decent opamps, we can get nothing from opamp swapping in this or similar amplifiers. Nothing but troubles, if we used improper parts. People just want to play with and they need to have certain beliefs, that's all.
P.S.: 5W "benchmark"
SINAD = 87.5 dB (NE5532)
I think this is quite interesting - though the amp is supplied from the SMPS which usually adds quite high artifacts at 70-80 kHz, the extended BW measurement is quite clean, even if I use no LPF measuring filter. The 2 big capacitors are only to eliminate output Vs/2 DC voltage from the single supply bridged A07 design.
But what about some discrete class A high-end opamps like Bursons, Sparcos and so on? Yours are just too similar on the paper.
I mean you cant really expect an moist sound with bigger soundstage from some cheap IC LME49720.
And whats the point of making the rolls on this limited cheap amp? You clearly need an Apollon or Audiophonics Hypex/Purifi with custom buffer to have a benefit from rolling.
Also why not using an DAC/HP amp for the rolling? Thats where the real magic happens! Its day n night!
What's the audio problem you expect to fix?
Op-amps are not critical in line-level audio applications. It's usually the least-critical circuit in the amplifier and it makes the least difference. People swap op-amps because they are often in a socket and it's easy. And since they aren't critical it usually works. Swapping a MOSFET requires soldering and if you don't choose a compatible MOSFET bad things can happen. Unsoldering and replacing the main chip in class-D amplifier is very difficult and you probably won't find a compatible drop-in replacement.
If you are making a high-gain preamp (a phono preamp or a microphone preamp) any noise generated in the op-amp gets amplified so you generally want a low-noise op-amp.
Amplifiers don't affect soundstage (in Controlled Audio Blind Listening Tests) unless the left channel is louder than the right or there is some other gross defect.
Again, what do you think is wrong with the "cheap" amp? If you can't hear a defect there's nothing to improve.
You'd be surprised how those "night and day" differences go-away in a controlled blind listening test.
And there's no "magic". With electronics there is ONLY noise, distortion, and frequency response. (With speakers it's mostly frequency response but room acoustics complicate things.) Audiophoolery explains the characteristics of sound quality.
Wow, - 97 dB HD3 without PFFB is quite an achievement. When did you buy these amps?
Back in 2021 they looked like this makeing me wonder if Aiyima added some PFFB without advertising:
What about time and phase?
Isn't it part of our perception and one that gets usually messed up with amplification and reproduction with speakers?
Op amps is about clarity, stage, range and colour of the sound. It is about what you hear not about numbers. All you need to know is that the op amp has similar power requirement that you are replacing.
This is a debate of a taste and we are all different. ne5532 that most of the D class amps have is OK and if you change it halve of the people can't spot the difference. We all have different hearing.
What can you hear that is not measured? (Spoiler: Nothing. Measurement tools are many, many, many times more sensitive and accurate than is even the best possible human hearing.)
I see you have just joined the forum. I recommend you check out this thread. Start at the start.
So you think that because I just joined my opinions are less value. I think you skipped your recommendation and still serving the same BS. Thanks for the heads up to ignore you.
No, this is a mischaracterization. I know your opinion is misguided, and I think misguided opinions are less valuable than informed ones. I think that because you have just joined you have not learned some of the very important basics that this forum has to offer, basics that, if digested, would disabuse you of some of the misguided notions you have espoused in your short time here.
No specification from proper/mainstream manufacturer of op-amp claims these things. What do you know that they don't???
Not at all. What I just responded to would be nonsense even if you had posted thousands and been here for years.
You just need to listen. Numbers matter zero nil zilch and if you can't show it on numbers it becomes an opinion and if you can't hear it your hearing is not very good. Do you think manufacturers can sell with an opinion? But we know op amps are made different for a reason. If there is no reason you would only have one model. Power needed and tone are all different. Do you deny this? If you can't hear the difference and others can it only means that your hearing is not good enough and that happens to all of us when we age or just didn't have it very good from the start.
No, you need to listen. Watch this:
So bunch of words from you matters but actual data from manufacturer and our measurements don't?
Yes, technical reasons which none of the people swapping them remotely understand. Op-amps have hugely varied application set and of course there is competition. This is why there are so many of them. They assume a proper designer is attempting to use the part so provide proper data sheets which say none of the stuff you claimed.
No, you are confused. I can give you two identical boxes, one painted red and another, black. Ask people if they sound different and a bunch of people say they do. Reason? They are not performing a controlled test with statistical rigor.
Let me give you a concrete example.
Our local audiophile group was invited to then one of the key writers/reviewers for stereophile magazine. We went to his home and he had a couple of high-end amps he was comparing. Room was small so we split into two groups. First group went in there, listened to bunch of music, and voted which amp was better. They came back and without telling us anything, we went to listen. We too were asked which sounded better. I did not vote because there was no way to tell given the poor protocol. But everyone else did.
We came back together and the first group asked which one our group liked better. The vocal majority answered to the shock of the first group as the pick was exactly opposite of theirs!!! Same test. Same room. Same protocol, but totally contradictory outcome with respect to what people "heard."
This is the problem with random audio testing that you all do. It doesn't generate reliable data. It generates randomness. Folks always assume there is a difference when many times there is not. Tests are not blind, nor repeated to rule out statistical errors. Watch that video. Learn how you properly evaluate fidelity. Then you are in a position to gather proper assessments. Only then you can come here and lecture us. Not before.
We know you are hearing differences. We would too if we were in your shoes. What separates us is that we don't trust those kind of tests. You on the other hand, have never learned the value of proper tests, nor studied research that indicates such, and are following along the same dirt road that get you lost as other audiophiles.
