jmdesignz2
- Joined
- Aug 19, 2025
- Messages
- 416
- Likes
- 228
- Thread Starter
- #81
you don't see a problem in the amp voltage burning out the Solo line input? You don't see any value in the speaker interaction with the amp?The acoustical output of speakers is solely determined by the applied voltage (output signal of the amp).
The amp in question is load sensitive so when you would record the electrical output with the speakers connected it should be O.K.
The Solo is not good enough for this experiment when the goal is to prove the difference in electrical output.
It is good enough for the TPA3255 and to record 'changes in sound' but not good enough as a measurement device for the op-amps.
I agree with your last sentence
