jmdesignz2
- Joined
- Aug 19, 2025
- Messages
- 405
- Likes
- 213
- Thread Starter
- #61
Hi- never claimed my subjective experience was "proof" and I clearly stated what I experienced was subjectiveThe TPA3255 is magnitudes worse than both the NE5532, Sparkos and LM4562 so no.... it really cannot get better than the TPA3255 which basically is THE bottleneck in performance.
The rationale was the recommendation by Fosi.
Besides ... even if the 2nd op-amp that was not replaced was just one half of the balanced signal and performance somehow increased through the presence of another op-amp there should STILL be a measurable improvement. There isn't any.
The 3rd op-amp (unbal->bal) you replaced isn't even in use when using balanced input.
Have you seen the testing done by @MAB and @pma ?
These measurements do not have the 'handicap' of the TPA3255 which determines the measured and sonic performance.
it only seems that way.
The TPA3255 is the limiting factor in ALL measured aspects.
Then YOU either DO a PROPER test yourself (blind, level matched, witnessed, statistic relevant and checked for operation) or you make use of proper tests that have been done.
Your subjective findings are not admissible as 'proof' I'm afraid.
Of course... alternatively ... you can trust your hearing and those of other 'op-amp swappers' (there are soooo many of them) and stop trying to convince ASR members that your hearing is trustworthy and we must believe you.
There is no objective evidence on your side nor is there any rationale on your side. Only your subjective observation.
You do realize that the frequency response (as well as distortion) in the higher frequencies are limited by the TPA3255 and the NE5532 and LM4562 both are magnitudes 'better' than that of the TPA3255 (and its output filter) which both have nothing to do with PSSR of op-amps either.
