Onkyo TX-SR3100 AVR 5.1-Channel used as XLR preamp - measurements
I case of clipping that you mentioned I'd suggest 1:21 attenuator (10k - 0.5k - 0.5k - 10k) which would provide 39VRMS / 21 = 1.85VRMS.
The 'clipping' I was talking about is not about the differential voltage but the common mode signal which in you case would +/- sqrt(2)*39/2 = 27 volts peak.
My suggestion was to make the divider asymmetric which will eliminate the common mode issue.
Halving the voltage by changing you design to 1:21 does not change the common mode signal.
You can also change you schematic by making the top 10k -> 20k and the lower 10k -> 0R.
Yes, I understand.
I did very elaborate testing pushing the AVR to extremes, with and without pin 1 lift, etc.
I never experienced clipping on the XLR receiving device side.
If what you describe is a common problem I should have seen it at least once, right?
Yes, I understand.
Indeed it could be something specific for the E-MU404 only..
But personally I would not take the risk having my common mode swing so much.
Yes, most likely your downstream XLR device had some specific voltage limitations, different circuitry design, grounding issue or potential difference which would cause it to behave this way.
It's possible..
Updates:
It's been more than 3 months of daily use already.
No problems at all.
The ONKYO works as it should.
I ordered a second unit yesterday for the 3rd TV room (family entertainment).
Price even dropped by $1 to $248. :cool:
