I am the owner of an Onkyo TX-RZ70. Thus my interest...@burkm, serious question: why is this RZ70 thread the focal point of your Onkyo/PAC news? I'd like to understand.
I believe the issue has been resolved with latest firmware. If you're sticking with Onkyo, aren't you better off waiting for the RZ-71 or is Dirac ART not on your radar?Hi all,
I'm looking to buy the RZ-70 in 3 weeks time (during Black Friday) and I was wondering if the issues with Dirac that were mentioned in the initial Audioholics review have been resolced. Also has the Dirac documentation been improved?
I'm not really bothered about ART. It really depends on pricing for the RZ71 compared to a good deal I can get on a new RZ70. From what I read, pricing for the RZ71 is going to be quite a bit higher than for the RZ70.I believe the issue has been resolved with latest firmware. If you're sticking with Onkyo, aren't you better off waiting for the RZ-71 or is Dirac ART not on your radar?
Yes, I believe the RZ71 will be significantly higher than when the RZ70 made its debut. You're better off waiting for the RZ70 on BF per your original plan.I'm not really bothered about ART. It really depends on pricing for the RZ71 compared to a good deal I can get on a new RZ70. From what I read, pricing for the RZ71 is going to be quite a bit higher than for the RZ70.
It it gets substantially higher, i think people may think twice about the Onkyo and go over to the Denon 6800HYes, I believe the RZ71 will be significantly higher than when the RZ70 made its debut. You're better off waiting for the RZ70 on BF per your original plan.
Everybody is running head over heels to get Dirac ART to work in their product and Onkyo is no exception. In order to be as robust and capable as Denon's offerings from 2022 2023, and early 2024, Onkyo will need to beef up their DSP and seriously get rid of the "unintended 4 ohm mode". That means adding heat sinks where they need to and with the cost of the more capable DSP, this should drive it closer to Denon MSRP.It it gets substantially higher, i think people may think twice about the Onkyo and go over to the Denon 6800H
The RZ70 (and images of the interior of the pre-prod RZ71) is very heavily engineered, with what look to be very substantive heatsinks. Those beasts are heavy, and they are very deep.... (there's a gotcha for people considering them, watch out for the component depth, a lot of cabinets do not have the required depth to house them!!!)Everybody is running head over heels to get Dirac ART to work in their product and Onkyo is no exception. In order to be as robust and capable as Denon's offerings from 2022 2023, and early 2024, Onkyo will need to beef up their DSP and seriously get rid of the "unintended 4 ohm mode". That means adding heat sinks where they need to and with the cost of the more capable DSP, this should drive it closer to Denon MSRP.
I heard at least one or more of the next gen Onkyos will offer the ability to process up to 6 discrete subwoofers. This starts to creep into HTP-1, Tide16, AT600, etc. territory for an AVR. Does that sound cheap?![]()
If you had read my post in the thread that is now closed, then you know I have many times on record mentioned that the RZ70 doesn't suffer from the "unintended 4 ohm mode". It was rigorously reviewed by Audioholics and Gene specifically looked for this type of power limiting.The RZ70 (and images of the interior of the pre-prod RZ71) is very heavily engineered, with what look to be very substantive heatsinks. Those beasts are heavy, and they are very deep.... (there's a gotcha for people considering them, watch out for the component depth, a lot of cabinets do not have the required depth to house them!!!)
I have not heard of any issues with Limp/Protection mode on the RZ70....
I did own some of its predecessors of past generations (Integra DTR70.4, Onkyo SR876) - which both had power amp sections that seem to be very similar to the RZ70 - at least specs wise! - and I can say that those past efforts coped well with my nominally 4 ohm speakers, with their nasty 1.6ohm minimum...
I would not expect to have issues with the capabilities of these receivers - they have a massive power supply with heaps of current, and substantial power amps, with massive heatsinks.... all the things that we really want to see in an AVR.
If Onkyo had supported ART on the RZ70, I would have purchased one - as it was, I was not willing to wait another couple of years for the RZ71, and I jumped ship to Denon.
From a pure audio perspective - the RZ70 has lots to recommend it (assuming the number of outputs is sufficient for your setup) - but ART is a "next level" upgrade, and without that, the RZ70 could not be seriously considered.
I expect that with the release of the RZ71, street prices for the RZ70 will drop, there will be bargains to be had.... and it will be a great value component - but one which will never be able to take advantage of a technology that moves performance a step beyond what was possible previously without architectural level work....
It is very sad that Onkyo chose not to support ART on the current generation - even though it clearly had sufficient CPU horsepower to do the job (according to comments during interviews with Dirac...) - Onkyo/Integra decided to invest in the next generation AVR, and use ART as an upgrade "carrot" - leaving the current generation as a technological orphan. (as a result they lost quite a few faithful Onkyo customers like me.... who mostly moved to Denon/Marantz)
www.audiosciencereview.com
Your least expensive option would be to get a discounted 3800 and use it as a pre/pro to external amps and wait for Dirac ART pricing this Black Friday.Now I'm starting to question my decision to go with the RZ70 ! LOL.
My set up is going to be 7.2.4 plus bass shakers for 8 seats (I already have two existing buttkickers LFEs and their 1000w amp from a few years back so I'll be adding 6 mini LFEs or Dayton Audios bst-2). I assume the tactile bass shakers don't require any eq from Dirac as they don't pump out 'sound' so to speak. Therefore I assume a 4 sub-out receiver should be enough for my set-up (2 to the 2 main subs and 1 to the bass shaker amp and maybe even 1 to the bass skaers directly)? I also assume I'll have to connect the seat shakers together somehow - i have to look into this.
I just purchased a JVC NZ500 projector today. I have an existing Yamaha 7.1 receiver (no 4k support , no Atmos, etc - basically it's about 14 years old!) that I could use in the interim.
As I see it, I can either purchase the RZ70 - no ART and, more importantly, no more than 2 sub outs. ($)
OR
Buy the Denon 6800HH - with option for ART and 4 sub outs ($$)
OR
Buy a refurb Marantz Cinema 30 (at about the same price at a denon 6800) - with option for ART and 4 sub outs
OR
Use my old Yamaha with all its drawbacks as a stopgap until the RZ 61 and RZ 71 hit the market. Maybe the 61 would do the job for me without having to jump up to the cost of the 71 (whatever that may be)? ($$)
OR
Buy some sort of pre/post combo with ART and 4 sub-outs ($$$)
OR
Buy a 9 channel receiver, and add an amp for LCR - with ART and 4 sub outs. ($$)
Phew.... Am I going about this the right way?
Yes and no.Isnthe denon 6800h better than the rz70?
