AV Receivers, Amplifiers, and Hi-Fi Home Audio | Onkyo
Discover great sound with our hi-fi home theater products including innovative solutions like Dirac Live and Dolby Atmos. Free shipping on all orders!
Why no measurements at 8 ohms?AV just measured the RZ70:
- stereo 264W 4 Ohm 1kHz Sinus
- 5.1 159W 6 Ohm 1kHz Sinus
- 7.1 88W 6 Ohm 1kHz Sinus
These are just slightly worse numbers than the A1H measurements, at least in stereo and 5.1.
If I remember correctly their reason was most speakers nowadays are true 4 or 6 ohm load.Why no measurements at 8 ohms?
If this is true, I'd like AVR manufacturers to get w/the program and report these numbers as well!If I remember correctly their reason was most speakers nowadays are true 4 or 6 ohm load.
Full measurements are:
2 channels:
205 Watt (35,1V) / 6 Ohm / 1 kHz Sinus
264 Watt (32,5V) / 4 Ohm / 1 kHz Sinus
5 channels:
159 Watt (30,9V) / 6 Ohm / 1 kHz Sinus
147 Watt (24,3V) / 4 Ohm / 1 kHz Sinus
7 channels:
88 Watt (23V) / 6 Ohm / 1 kHz Sinus
AV? do you have a link?AV just measured the RZ70:
The big weakness with most AVR's is that they have a single power supply - shared across everything - and that means once you start to drive more channels, you start to run out of current... and the power drops off.....All the new AVRs seem to have a high drop from 5 to 7 channels. But that's really not that important for anyone who has a sub.
I ran full range bi-amped fronts (7ch) for 13+ years so I was doubling my LR consumption and pushing low-end frequencies and it never complained or felt compressed.
The moment I got a sub even with my lower crossovers, it barely heats up. It's those 2 octaves at the bottom that seem to demand the most power.
In fact, given the fact that people will run at least 1 sub with these, I'd rather see smaller transformers capable of higher 3 channel wattage (3x150 watts or 4x120), more capacitance (60k-100k), smaller toroidals, copper chassis for better isolation and other things to improve sound. Put the money where it matters most.
If someone needs more power, they can always get a small external amp for a few channels but they can't increase the quality of the main unit although these do seem really well built but it's sad to see the omission of a toroidal even if it cost $100 more.
audiovision.de
Sounds logical.In fact, given the fact that people will run at least 1 sub with these, I'd rather see smaller transformers capable of higher 3 channel wattage (3x150 watts or 4x120), more capacitance (60k-100k), smaller toroidals, copper chassis for better isolation and other things to improve sound. Put the money where it matters most.
On that, I would caution that there are many internet hearsay/audio myths and the toroidal story is one of them, though in general, all else being equal, toroidal power transformers tend to do more good than bad in AVR/amps applications. You will certainly find someone who specializes in manufacturing or marketing toroids that tell people toroids are the best choice for audios, that's marketing 101.If someone needs more power, they can always get a small external amp for a few channels but they can't increase the quality of the main unit although these do seem really well built but it's sad to see the omission of a toroidal even if it cost $100 more.
AV is the German magazine Audiovision.AV? do you have a link?
Sounds logical.
You just can't generalize too much, as EI core, R core and other designs also have advantages that may make them the preferred choice in some applications. Many cost no object kind of amps also use non Toroids, such as Luxman, McIntosh (some models). Back to AVR, Denon has been using their custom designed E-I core for their flagships in recent years, including the $6,500 A1H, but they also use toroids in their older models. There are also many low cost amps (I have a couple) that uses toroids, it is not always a case of "$100 more". The fact is, some toroids are better, some are not, it depends on how they are designed and made, and the specifics of the applications such as the layout, and yes cost could, and often be a factor too.
We've had that conversation a few times and I agree mostly because I grew up with the Sansui 8080 and that didn't use a toroidal.
But Sansui did use dual toroidals in their best receiver the G33000. It's a tough one because you have the 8080/9090 and then you have the G33000.
Speaking of the AH1, the 5803-06 had toroidals so in Denon's case they are probably saving money. It's a bit cheesy to buy a $6,500 70lb top-of-the-line AVR with an EI when Monolith has dual toroidals for 1/3rd-1/4th the price and weighs 93lbs. Also how is the AH1 isolating the AVR from external interference? I know Marantz uses copper chassis on the 8000 series and PM series and Yamaha does similar stuff on the power supply so what does Denon do?
We should be calling them out for that.
That's funny - I have no clue what it is. They chiseled the top plastic cover to fit the cables. It's clearly fairly modern given its heatsink (black - is it painted or an alloy) and I see lots of copper on the sides and on the screws. The capacitors are in some sort of enclosure too - interesting.Gene thought Denon uses E-I likely because of the layout that would make it difficult to fit a toroid that provides the same VA rating. I have quite a few power amps, the cheapest ones (not including my class D amps) happen to have toroids. My vintage Marantz power amp has EI. I can't imagine Denon picked an E-I for the A1H, A110 and 8500 just to save a few dollars, but it is of course possible.
Here's one example of why toroid is not used, and not because of cost:
It's another $6,000 Denon flagship amp, a 50 W, 8 ohm, 100 W, 4 ohm, 2 channel stereo analog only integrated amp:
Hard to tell it is E-I, R-core, but it's unlikely a toroid, externally it obvious look like an ovoid lol..
My question is what happens if you plug in speakers with 3.2 Ohms DC resistance and drive them at reasonable power.![]()
Discover great sound with our hi-fi home theater products including innovative solutions like Dirac Live and Dolby Atmos. Free shipping on all orders!onkyousa.com
Feel free to look at my signature for the answer to your question.My question is what happens if you plug in speakers with 3.2 Ohms DC resistance and drive them at reasonable power.
I seem to recall Amir giving up on the Onkyo TX-RZ50 when it instantly went into protection mode when a 4 ohm load was applied.
Has anything changed with new ownership, or can we expect the TX-RZ70 to choke on "real" 4 Ohm loads?
I would say just knowing the dc resistance is not enough,. To answer your question, I would like to know the impedance and phase angle vs frequency curve. Also, it is more useful to look at the voltage and current requirements than power, though if the amp is really powerful then it will usually do well in both.My question is what happens if you plug in speakers with 3.2 Ohms DC resistance and drive them at reasonable power.
Agreed, but it's not regulated, so it is unlikely that they would do it on their own. In practice, it is not that bad either because if the spec says 100 W 8 ohms, the amp will do more for 4 ohms for speaker loads and for real world use, at least in most cases. For use with truly 4 ohm nominal speakers that can handle a lot of current, then it will be a good idea to use external amps rated adequately for the load.If this is true, I'd like AVR manufacturers to get w/the program and report these numbers as well!
