There's still a misunderstanding here. The SW volume or gain as it should be called should be adjusted once and never touched again, especially AFTER speaker calibration for the first link in my procedure. That speaker calibration is to match levels across the board. If you go about fiddling with the gain after calibration, you might as well not calibrate at all!
It's not a misunderstanding, it's a matter of preference. I have hundreds of albums on CD, Vinyl, purchased digital files on a media server drive, audio Blu-rays, SACDs, and even one DVD-Audio and one DTS CD. I also have hundreds of Blu-rays and 4K Blu-rays. That means that I have over a thousand different pieces of content, all with different bass, as I already explained twice.
So why would I set my subwoofer to one gain level when I know that it's going to sound great for some of that content, then it's going to sound excessive and house rattling for other content, and rather boring and small for other content? It seems to me that you guys don't listen to the amount of music I do from several different decades, and you watch movies from just the current and last decade, if a static subwoofer gain is good enough for you. It's definitely not for me. I love bass, so I want to hear it, at enjoyable levels, not excessive, and not poor. Just the right amount. If I choose the option that doesn't let me change the gain in the subwoofer, I'd be stuck with the same amount of sub-bass for everything. I'm a tweaker. I'm the guy that's adjusting everything to always get the best sound and picture, if it's a movie.
If you haven't learned by now, all the adjustments are made while in the Dirac environment (to your liking).
No, I learned that early on. And I wouldn't mind so much if it allowed to play music while working on the curve.
If you don't like the sound after a proper Dirac calibration, then Dirac is not for you (a conclusion that nearly everyone in this thread is coming to).
You might conclude what you want, I don't care particularly if you or anyone think Dirac is for me or not. The only thing that makes Dirac worth the $1,100 + tax I paid for the RZ50 is the parametric EQ. If it wasn't for that, the Pioneer VSX-935 is a much better unit because it goes up to 12 dB for each band. It baffles me that the same company decides to put a poorer version of the native equalizer in a receiver that is more than twice the price of the VSX-935. Why cut the bands at 6 dB? It doesn't make any sense. When I tried my best to use the internal EQ to my taste, I couldn't get close to the sound quality of the Pioneer. It's the parametric EQ in Dirac Live that makes this unit better than the Pioneer.
It's just that the process is a royal pain in the butt. All the measuring with so many positions, then everything else is backwards. First you have to switch to the points editing, then to apply the same curve that you did to the front channels to the rest, you have to save it as a file, then you have to open the menu again, go to load, then all groups, then load that curve for all the groups. It's idiotic. Why not have a simple command that applies the front group curve to all the others except the subwoofer?
But applying the curve is just part of the job. Then you have to go group by group to open the "curtain", because as it is, it's only open between like 200 Hz and 2 Khz. What the hell is that about? I want my curve to affect the full spectrum, not just a narrow range of frequencies.
Then I have to push the curve to the receiver, which given that it's just a few KBs, it should be instant, since my PC and the Onkyo are both connected to the same router with ethernet cables. It's a rather new router from a year ago, and my PC connects at 2.5 Gbps to it, and I assume the Onkyo at 1 Gbps, but even if it does at 100 Mbps, it should transfer the file in a second, and it takes several seconds.
Everything in this program feels like it was designed to be unnecessarily complicated and take more steps than it has to for no good reason. It's upsetting to see something that could be so much better, be such a pain to use. I shouldn't have to waste hours first running the tests, then adjusting and pushing, adjusting and pushing. This should be much more simple and effective. I should be able to load the web interface for the RZ50 like I do many times, there would be a parametric EQ as part of that interface, with about 20 points, and I should have the easy choice to apply that curve to just certain speakers, or to all of them if I want, without having to do weird workflows like saving the curve to a file, then load it for all groups. Who the hell designed this? Do they know anything about UX?
Or, if it has to be through the Dirac Live app, fine, but give me that curve without having to waste time positioning the little mic on several places, just one is enough, and let me adjust that curve while listening to music. That way, I put the latest Foo Fighters album, followed by Metallica's black album, followed by James Newton Howard score for Signs track 12, then Tchaikovsky's Romeo and Juliet on SACD, and finally Miles Davis' Kind of Blue on vinyl, followed by Tears for Fears' "Seeds of Love" audiophile vinyl. Still would take me some time, but it would a hell of a lot more enjoyable than sitting still not making any noise at all while I keep hearing wooooop! wooooooop!.
It shouldn't be called Dirac Live. It should be called MASTSE.
Most Annoying Sound Tweaking System Ever.
You fellas can defend it to death, but I'm going by simple common sense here. I want to adjust my sound to what I find pleasing, not to what the sound engineers at Dirac think it is. Which is basically what you're doing with these measurements, setting up the sound to what they think you should be happy with, and I don't care for it.
What I know without a doubt is that if I invited each and every one of you to this room and play some music, all of you would say that this sounds amazing. Which is what everyone who has a chance to listen to music or watch a movie here says, and said even with the Pioneer VSX-935.
Dirac doesn't allow you to fiddle after the fact on the lower end units.
Well, I'm far from rich, in fact, if I had a sound system adequate to my income, I would be the typical guy that calls a sound bar "home theater". So this may be a "lower end unit", but to me it's the most expensive receiver I've ever bought, and for the most part I like it, it's just annoying to go through so many hoops to adjust the EQ to my liking.
