Doesnt it have Dolby Loudness? Or you can just save 3 different curves on the presets and switch depending on our particular level during movie watching.Is there any loudness curve function in the RZ50?
Edit: looks like none can be used with Dirac??? Eg: THX Loudness Plus can not be used with Dirac.
I don't see Dolby Loudness in the manualDoesnt it have Dolby Loudness? Or you can just save 3 different curves on the presets and switch depending on our particular level during movie watching.
The EBay special?Can't wait for Frys era AVR pricing! Looking forwards to 60%+ off!
Its a good sign. The VSX-935 cost about $1200, where I am from, a series that once cost around 400-500. The whole market is a mess.Maybe Onkyo will come next.
Premium Audio Co. Rolls Back Pricing on Select Klipsch Speakers and Pioneer Elite AVRs
(May 1, 2023) Following years of industry-wide price hikes and shipping delays, we're finally seeing movement in a favorable direction for consumers. Beginning today, May 1st, Klipsch Reference Premiere speakers and Elite audio video receivers will match 2019 prices. That makes for discounts up...www.avnirvana.com
Frys used to sell brand new AVR at crazy sales prices. They are a fully authorized dealer too.The EBay special?
The 3800 will receive DLBC support next year, in which case you can skip the miniDSP. But otherwise they are both good options.Hey all
So the RZ50 is on sale here in Australia. Historical low of $2024.
Denon x3800h is currently its regular price of $2499.
Plan on using it with external amplification (Yamaha A5200) with a 7.2 setup (subs are SVS pro, so have basic onboard custom eq).
Is there a reason to pay extra for a different AVR in my case?
Needs:
- HDMI 2.1 (for gaming consoles and gaming PC)
Wants:
- Dirac
With the eq of the svs, do I still need to get a Minidsp? Does that increase in cost make something else a better option over the RZ50?
Thank you
Thanks. Think I’ll stick with the Onkyo.The 3800 will receive DLBC support next year, in which case you can skip the miniDSP. But otherwise they are both good options.
Ok so first. Personally I didn't love the psa speaker sound at least not the center.Trying to decide between the Denon x3800h vs the Onkyo RZ-50. Both refurbished right now are around $1,000. The main benefit I see is Dirac for the Onkyo as it is built into the price vs paying an additional license fee and having to buy a microphone. I mostly want to use it for Home Theater use with some music use. I am right now deciding between using the KEF R11, R2C, and R3 as surround or KEF R7, R2C, and R3 as surround, or PSA MTM 210-M, 210C, and 110SR for surround.
Can I not just use an SPL meter to match vs using Dirac or Audyssey?
The 2 independent subwoofer option on the Denon x3800h is really appealing, but the RZ-50 has newer features and Dirac. I have 1 HSU subwoofer right now, but plan on buying a second HSU or maybe a PSA subwoofer.
Also plan on adding two rear height speakers for Dolby Atmos wall mounted to the back wall so my ideal set up down the line would be an 5.2.2.
As a previous owner of svs and hsu, I would just go for the psa sub directly. They are in a different league completely. I had the tv1812 and now tv2112 duals. They are jaw dropping.
For atmos, I HIGHLY recommend you do 4 as it is the minimum to experience true atmos. Also you need to place them in the right location based on angles otherwise it would be subpar.
No..and SPL meter is not remotely close to what Dirac can do.
I would get the rz50 because even though I was a Denon fanboy, after Dirac I just can't go back.
The 3800h does have directional bass and 4 sub outputs although it's auto calibration of my 4 subs at the time was subpar. I do much better using a miniDSP.
If you are placing the subs in different locations and/or mixing subs then a miniDSP is a must have with a umik
I only tested it for HT.For the PSA Speaker, you mean for HT you didn't like the sound or for Music or both?
I think at most I will go with 2 subwoofers, but PSA subs are a bit expensive will have to be a year or two before I buy those $2k and up ones.
I have 2 Axiom QS4 v3 from my current surround system that I was thinking of repurposing as rear height speakers. I can't do ceiling, but maybe can do front height too behind the T.V. down the line.
I was planning on placing my HSU Research VTF-2 MK 4 Subwoofer I have right now by the two couches to be close as possible as a cheap option for bass shakers and the other subwoofer which might be a PSA or maybe a HSU VTF-3 MK5 directly across from it
The current placement of the subwoofer is to the left of the TV with the back against a wall in a corner underneath a countertop. The other side of the TV opens into the entrance which has 20 foot high ceilings, tiled floor in the entrance from hardwood floor in the family/movie room, an angled half wall that is part of the stair case with 2 display cabinets lining against that half wall.
I sold my rz50 but never had issues with connection dropping and mine was in the basement so pretty far from my routerHas anyone experienced issues maintaining a stable wifi connection? What did you do to fix it?
I have tried 2 routers, 2.4ghz and 5ghz channels, hot spotting from an iPhone, but the connection will last about 3 minutes and then drop out. It seems almost too consistent to be an error. Haven't even gotten through one song yet.
Thanks
