For an amplifier what is the easiest thing to do, for more power ?
Maybe lowering the resistance of speakers is done for letting them use more power with the same amplifier technology...
- Higher voltage ?
- Or more current at the same voltage ?
Not sure what you are really asking, but I would only say that if your speakers have high nominal impedance such as 8 ohms or higher, then make sure your amp has higher than enough voltage output. If 6 ohms or lower than focus on current capabilities, make sure it could deliver more current than your speakers may draw.
To be on the safe side, and/or without having to worry about enough or not, use amps that have more than enough rated voltage and current outputs.
Since most, if not all speaker manufacturers typically published "power requirements with no mentioning of voltage and/or current" (unfortunately), so in general, if your speaker's recommended power requirement is 200 W maximum, then if an amp is rated say, 400 W into 8 ohms, you shouldn't need to worry about voltage or current, you will be covered.
