Onkyo TX-NR7100 AVR Review
Rate this AVR:
    Votes: 163 71.8%
    Votes: 48 21.1%
    Votes: 11 4.8%
    Votes: 5 2.2%
Is it a new discovery? I don't see any indication of this problem in distortion measurements by Amir.
Subjective comparison between a robust Onkyo and Integra flagship AVR's, Quad 606 and XLS2500 power amps and the Integra DRX3.4 AVR (same amps as the NR7100) - only the DRX3.4 sounded less than perfect driving my speakers - all the others handled the speakers fine and sounded as they should.
The speakers are a 4ohm spec/nominal, design but with 1.6ohm minima.
My 1.6ohm speakers (4ohm nominal spec) - connected to my Integra DRX3.4 - sounds like rubbish - imaging is confused, vocals are poor... then you use the DRX3.4 as a preamp and feed it into my Quad 606 or Crown XLS2500 and it suddenly sounds the way it should.
Same speakers sounded identical to how they sound on the 606 or XLS2500, when running off my Onkyo TX-SR876 or Integra DTR70.4 - both of which are high current AVR's.
The Integra DRX3.4 / Onkyo NR7100 / Pioneer LX305 (all of which have identical amp circuits) - are NOT recommended for 4ohm speakers.
(and I am not talking about the so-called protection mode... which I did not encounter, even though my speakers are a particularly difficult 4 ohm design)
Any speakers with difficult load needs separate amps for any ave.
1.6ohm is very low. Most AVRs and a lot of amps will have an issue driving that. I don't think most 4ohm speakers even drop that low, it's usually just a few.
Like I've been saying - 8ohm speakers (nominal) should be fine, 4ohm speakers can be a problem - This is not a high current amp, and is not well suited to 4ohm nominal speakers... even the mildest 4ohm Nominal speakers tend to have dips down to 3ohm.
And yes I know that my speakers are relatively unusual... but they really do demonstrate the point.
I chose to purchase the DRX3.4 rather than the NR7100, because it has a full set of pre-outs, in the knowledge that I would most likely need them is it would probably not cope with my mains. - That assumption was proved correct.
However the DRX3.4 has demonstrated that it is an excellent prepro - and its handling of my surround and height channels (via its internal amps), has shown that it is just fine within its speaker matching constraints.
These AVR's are great value, and provide excellent performance, but you do need to match them with the right speakers, or use external amps with them in the case of the Integra DRX3.4 or Onkyo RZ30.
Not always, the vintage Onkyo SR876 and Integra DTR70.4 coped without trouble - the similarly endowed current generation RZ70, DRX8.4, LX805 should handle difficult speakers without trouble. - Horses for courses...
Ya had I known the 3.4 was going on sale for $20 more than the NR7100, I would've bought that instead. I didn't find out until months later.
On the other hand, I think people tend to worry too much about narrow dips in the impedance curves of speakers.
Sure - if you are driving test tones, then when you test into that narrow dip, all the power is at that frequncy, and a current limited amp is going to struggle if you are trying to generate full power at that particular frequency
However, music is a wideband signal. The energy focussed on a particular dip will be relatively small proportion of the overall energy, and the current demands are going to be correspondingly small also.
Obv it can become an issue if you are trying to drive a 4 ohm speaker at the full power capability of the amp. But if not most amps - even AVRs' will cope with typical 4 ohm speakers. Though perhaps not yours.
Exactly, but if a speaker dips to 1.6ohm for example, then it most likely has an overall low impedance around say 3ohm, but they label it a 4ohm speaker. That could be an issue for a lot of AVRs. IMO if you are buying speakers you should be using measurements to make your choice, and you should be aware of it's impedance graph.
80. Dirac sets them to 70, again sounds really good.
As bass management for Dirac is strictly on the AVR-side (Onkyo), I'm not sure how Dirac is "setting" it to 70 Hz. The 7100 doesn't qualify for DLBM or DLBC.
I have nothing to prove to you. Dirac sets all peakers to 70 and sub to 120. Screenshot doesn't show sub but in menu it can be seen it always sets sub to 120 and all speakers to 70 after calibration. FWIW, I have this receiver for a couple of years now, played with it a lot, tried different rooms, ran Dirac on it many times, etc.
Base Dirac does not ordinarily do anything with bass management. Perhaps the Onkyo app for some reason conflates Dirac and crossovers, but that 70Hz value is not in any way somehow calculated to be the ideal crossover. It's just a default setting.
My JBL HDI-1600 (4 ohm) sound phenomenal with NR7100.
They are a "true" 4 ohm design, measured by Amir at 3.8ohm absolute minimum.... which makes them fine with the NR7100 - where the low to midrange AVR's get into trouble is with 4ohm designs that have extremes down to 2 ohm or below (like mine!) - which is not uncommon for 4 ohm designs - hence my repeated cautions when combining 4 ohm speakers with the NR7100 or RZ50... - Check the impedance charts!
Might that be where Dirac is setting the "curtains"?
Here is the review/measurements of that speaker...
No idea. I just know that regardless of what I set crossover to, once I perform calibration (via Onkyo Controller app for phone) it changes it for all speakers and sub.
If you use the PC app, you will get more detail, and more control - (which won't necessarily improve the end result!)
But for the geek/audio-nerd inclined, it is interesting! (and you get much more fine grained control if you want it)
Absolutely. Umik-1 arrives tomorrow (well, today, I'm in ET) and this is when I want to use Dirac on my laptop. The reason I've used basic mic and the phone app the entire time is that honestly I'm quite happy with the results. There were times where I found myself spending hours, days even, building and then tuning something, configuring, reconfiguring, etc... instead of actually listening to the music and watching movies. I'd like to change that, and I've made some progress.
