With audio amps, not so.. and it is not too meaningful to say two 100 W rated amp have the same output, without knowing a lot more details about that 100 W spec.
Correct. My Luxman R-117, for example, hypothetically is a 160W receiver, but because it is a rail shifter, it will actually do peak power of a ridiculous 450 watts for a fraction of a second. Musical transients last only for a fraction of a second--none really longer than about 50ms except possibly sustained pipe organ pedals at 15Hz, or various electronica/dubstep type of stuff. So it
behaves like a 400+ watt amp on program material. The same is true of any home theater receiver, musical transients that are hitting those +10dB or +20dB over mean levels last only for a fraction of a second.
Relating that to the Onkyo, it will happily sustain rock music with an
average level from a single speaker slightly louder than a lawnmower all day long, at the listening position, on the proverbial 87Db/1W/1M speakers using, say, 35W to hit that average level. And it should bang out those transients all day long without triggering the protection, but will clip somewhat. It will sound the same as any other comparable amplifier which peaks out at 170W before it clips, since only around 7dB of dynamic headroom is available at those levels. 3dB of the peak transients will be clipped. On a transient which is 10dB over the RMS mean, the Luxman, on the other hand, can play just as loud, with no clipping, since we have over 10dB of headroom at 35 watts (i.e. 350 watts).
But now let's hook up some really inefficient speakers, so 84dB/1W/1M. Our average level now MUST lower to hairdryer or blender levels, since we can only sustain around 91dB on average. This level is safe for two hours, maximum, before hearing damage sets in. If we do not lower the level, the Onkyo will have insufficient dynamic headroom to play much of anything short of Metallica's Death Magnetic, arguably the worst recorded, most insanely compressed album in history. It is unlistenable noise on a decent stereo. Plus, you now
might trip a protection circuit if you try to keep it at "lawnmower" levels on these ridiculously inefficient speakers. The Luxman, on the other hand, is now performing on par with how the Onkyo performed with the previous 87dB speakers--okay, but not really. It needs to be turned down to hairdryer/blender average levels, as the Onkyo really should have been before.
I realize this is belaboring the point, a bit, but I think it is important to understand how these protection circuits work, why the engineering appropriately is how it is, and why it is not a genuine problem in usual situations. It's important to me that people get the best sound they can for the most reasonable price. This product is the answer to that for vast numbers of budget constrained audiophiles. I gave this a lot of thought previously when considering the RZ50. The reviews here, while extremely helpful, nearly knocked it out of consideration because it does require some thought to realize there is no actual issue. You also need to composite all 5 or 6 of the reviews and review all of those measurements to figure this out. It takes
over thirty seconds of severe abuse to trip the circuit. That is an eternity in music into speakers, but not for a sinewave into a load resistor. These units (RZ50,SX505,SR7100,SX303) have been getting dragged through the mud here for 2 or 3 years over a
non-issue on music. The actual science and measurements of musical loudness (crest factors) and acoustics, on top of user reports, belie the implicit assertion that vast numbers of users are running around not getting the power they paid for. Unless they are heavily clipping their systems, they must be getting it.
Yes, these units have some minor foibles, and Denons
might have some measurably better performance in certain areas. However, Onkyo offers Dirac at a price level at least $500 cheaper than comparable Denon units with XT32, particularly so now that Denon wants a minimum of $1600 for anything with XT32. If you don't need external amps, this Onkyo/Pioneer often can be had $800 to $1000 cheaper than Denon, which does not offer a competing unit. High precision room correction (i.e. not Audyssey XT, MCACC, YPOA, etc.) is likely to make a
vastly larger audible improvement in the
average system than anything else, period, end of story, do not pass go, because any other answer is
wrong. This has been proven and demonstrated time and time again with solid measurements. Even if there are minor issues, or SINAD or whatever could be better, little of it matters on a macro level compared to the benefits room correction will bring.
