Blumlein 88
- Joined
- Feb 23, 2016
- Messages
- 23,571
- Likes
- 44,693
Yes, this is something I've wanted to either do myself or hear done. My first impression of the Blumlein recording is they put the mics a bit too far out. So I prefer the LCR recording, and am not surprised it sounds closer. I'll need to listen a few times and see what I think in regard to other aspects of spaced vs coincident. I'd also note when you record with figure 8s in a Blumlein array it works the best if playback has 45 degree spacing of the speakers vs the center position rather than the more common 30 degrees in most playback systems.Core Sound just posted something interesting about this on their FB page.
Which Sounds Better: Coincident Microphone Array or Spaced Microphone Array?
We recorded a 60-voice choir performing in a great sounding room. We recorded the performance out in the room rather than with spot mics on the stage.
Does recording with a coincident array using a single higher-order ambisonic microphone better recording with a spaced array using two higher-order ambisonic microphones?
The coincident array was decoded to Blumlein (virtual coincident array of two crossed figure-8 mics rotated 45-degrees).
The spaced array was decoded to LCR130 (three virtual hypercardioids spaced at 14 cm and angled at -65, 0 and +65 degrees).
You decide!
Blumlein
LCR130Half Acre - Blumlein.wav - Shared with pCloud
Store, share and listen to music with pCloud. Access on any device. Create a free account now!u.pcloud.link
Half Acre - LCR130.wav - Shared with pCloud
Thanks for posting this.
