On the Distortion of Cirrus Logic CS431xx-Based Devices: A Comparative Review
How would this review influence your purchase decision of a device employing Cirrus Logic CS431xx?
  • Going forward I will not buy a device if it adopts any Cirrus Logic DAC chip.
    Votes: 31 13.4%
  • I would not consider any device with CS431xx.
    Votes: 20 8.7%
  • I'd consider a device with CS431xx only if it's been tested free of the "Cirrus hump" distortion.
    Votes: 118 51.1%
  • I don't care about this distortion issue and would just consider the device's other features.
    Votes: 62 26.8%
It would make sense since DRE seems filter-related...
I've always assumed that the "NOS" removal of DRE was a design artefact. In theory the "Dynamic Range" aspect of DRE should be agnostic of input type, so towards the end of the logical functions. But I guess it just may not be in circuit for different paths through the DAC.
Thinking further, if DRE is designed to make a relatively meh core DAC measure better than it is on a standard test rig, perhaps it only needs to be switched on when measuring PCM at 44kHz, since that's the standard test case.
Per CS431xx datasheet, NOS mode is minimizing internal digital processing. If it is the intent of that mode, also disabling DRE seems logical. But the datasheet gives no additional information (that I could find).
just got the truthear keyx. and did the cmaj test. i didnt hear any crackling at all. it seems like ttgk/truthear disabled DRE by default or set it in such a low threshold much lower than the black pearl's. its pretty much inaudible.
Nice, it's available for a while at the local store but I ended up buying 7hz 71 instead (nearly 50% cheaper). I wish I took the chance at this since it's so much simpler.
It is not really a competitor to something based on CS43131 since it is 1Vrms dongle, but that is a nice price, I've paid $30 for 71 in 2022 (regular price was close to $40). Unfortunately I couldn't shake the feeling that the middle mids are boosted and it annoyed me so much I stopped using it (it worked perfectly for V shaped IEMs though) + it ran a bit too hot and sipped a bit too much battery for my liking. I apologize if I'm sounding like I'm trying to put a downer.
Some measurements, although for some reason I remembered SiNAD to be 104dB at 1Vrms, so maybe there were some other ones higher as well
https://www.audiosciencereview.com/.../jcally-ap7-and-7hz-01-usb-dongle-rmaa.38980/
Can't find it now, but there were pictures showing the same PCB in 71 and JCally AP7.
Btw Focusrite Scarlett gen4 series also use CS431xx, so might also need to be tested?
Interesting ,since its aimed at professionals,most CS431xx application were on consumer oriented devices these days.So far most pro manufactures go with ESS pro series or AKM (more rare since there is chip shortage from what i read). To be honest so far in all the dongles is used with CS4311xx family DRE on/off didn't have difference ,didn't do the test to detect it though ,just listening to the music files i hear for regularly.
Target Market: Pro Audio
Something already exist:
Thanks for the info, looks like also affected? https://www.audiosciencereview.com/...2-4th-gen-interface-review.58790/post-2150074
It seems very appealing and could be the "perfect" dongle but I didn't find any measurement...
Those are more entry level devices which nowadays are often bought by amateurs. With expansion of the interface market to streaming, people doing their own music, wanting better mics just for gaming, and also guitar playing via computer being supper common, it wouldn't be far from calling it at least a prosumer products. Unfortunately aside Focusrite Scarlett (there is also a report of distortion in this very topic), also Audient iD series were found with the issue (annoying since those had much more powerful headphone output than Scarlett).
Anyway, from what I recall the issues with CS43131/CS43198 were first reported by dongle users who heard it in normal use. Those were often dismissed as faulty units or wider setup issues, because others with the same dongles didn't. At some point we got RAA look into and make test for "clicks" specifically, attesting the issue to class H, but it actually took a few years before jkim here identified DRE as the underlying cause and hence the full scope of the problem (including not only being limited to those 2 chips).
I feel like the Truthear looks nice but might actually not be good for the USB sockets as there's the potential for twisting force
Hey all,
Rather than post the same thing in two different threads, I am posting the link to a post I made in another thread here:
I have come across an issue with my TRN Black Pearl that could be applicable to this thread as I have discovered some form of distortion/hissing noise while using the NOS filter + 3.5mm connection with my iPhone 14. This wasn't known to me until tonight because the issue doesn't happen when using the BP's 4.4mm connection. All of the scattered details are in that post.
Since i couldn't find a dedicated post for it i will post here ,sorry,since we talked about hat dongle as well. Today my Ibasso Dc04Ultra was not detected by my phone when i went out for a walk.Yesterday it was fine.Thought its either the cable or dongle went bad.Went back home tried 3 different phones and a PC, nothing!Then i accidentally pushed on of the side buttons ,cant remember probably the menu and it lighted up and got detected!Strange i have this for 10+ months use it everyday never happened!
This is late to the party, but I have found what I believe to be another music test track that is arguably more revealing than Hans Zimmer “The Dune Sketchbook” ‘Song of the Sisters.’ Interestingly, it, too, is recent film music. Try Ludwig Göransson “The Odyssey” ‘Zeus’s Law.’
About 90 seconds into the first track, deep bass drones for an additional 90 seconds reveal copious clicking artifacts on some affected DACs. The audibly worst clickety clack offender by far that I have on hand is the current Apple USB C to 3.5mm dongle, while a new old stock (2016) Apple Lightning to 3.5mm dongle is minimally affected, if at all. The latter minimal to inaudible characterization also holds for the FiiO KA11 dongle — both USB C and Lightning variants.
AJ
