On the Distortion of Cirrus Logic CS431xx-Based Devices: A Comparative Review
How would this review influence your purchase decision of a device employing Cirrus Logic CS431xx?
  • Going forward I will not buy a device if it adopts any Cirrus Logic DAC chip.
    Votes: 31 13.8%
  • I would not consider any device with CS431xx.
    Votes: 20 8.9%
  • I'd consider a device with CS431xx only if it's been tested free of the "Cirrus hump" distortion.
    Votes: 115 51.3%
  • I don't care about this distortion issue and would just consider the device's other features.
    Votes: 58 25.9%
The Class H power supply mode (register setting ADPT_PWR = 111) is a power saving mode. It is made for mobile devices to consume less power. The noise will disappear if you change Class H mode into Class AB mode (register setting ADPT_PWR = 001).
If the question from the previous posts is about the “Cirrus Hump” noise/artifacts, the Class AB/H mode has no impact. This was tested by @jkim .
Hello. I registered with ASR because I wanted to report this issue.
Fiio KA5 has received firmware version 1.70, which includes a "DRE optimization function," resolving previous DRE issues.
However, a crackling noise very similar to the DRE problem has now appeared at low volumes.
This new noise is audible when playing "Original_CMaj.flac" at low volumes of approximately Vol 25-45 (High gain/4.4mm balanced output).
It also occurs when increasing the hardware volume and lowering the software volume.
Changing the digital filter to "NOS" completely eliminates this noise.
This indicates that this noise is related to the DRE.
Since the KA5 does not have a function to turn the "DRE optimization function" on or off, I decided to downgrade the firmware to v1.60 to circumvent this problem.
The same noise is also audible on the Tanchjim SPACE, which also has the "DRE optimization function".
I contacted Tanchjim support, but they didn't acknowledge this issue.
It seems to me that the "DRE optimization feature" offered by Fiio and Tanchjim doesn't actually resolve the DRE-related noise, but rather makes it more audible.
(Vol25-45 are the volume levels I normally use.)
Unfortunately, I don't own any other models that claim to address the DRE issue, so I can't do any further testing.
Have any of you noticed anything if you own those models?
Where are these measurements?
I don’t remember if @jkim showed the actual measurements in some post, but he did check this—see this note on the first post:
Note. This distortion behavior does not depend on the device's playback sample rate, impedance load, or any firmware settings like digital filters, Class H/AB modes, etc. (if available)---it always occurs regardless of such conditions. The Fiio BTR13 was not included here due to its 16-bit resolution masking distortion to some extent (instead, see below for its TDFD bass distortion measurements).
One of the idiosyncrasies of the CS431xx is that the NOS setting also turns DRE off (Cirrus may have some good technical reasons to do that, I don’t know).
Some OEMs hinted that their “optimized DRE” setting acts like a noise gate, turning DRE on/off depending on the volume. I don’t know how FiiO & Tanchjim have implemented their DRE feature.
There are dongles with a 3-position settings: DRE on, “optimized”, and off.
Although the FiiO K11 is a desktop device, it is based on the CS43198 chip, commonly known from dongles.
Unfortunately, it appears to suffer from the "Cirrus DRE hump".
I'll try to ask FiiO if they could implement the ability to disable DRE in the next firmware. In the meanwhile, I'm using it with NOS filter workaround.
Measurements:
FiiO K11 24/96 Optical In - RCA Line Out
measured using MOTU UltraLite-mk4 (ESS version) with RCA to TR Jack adapters
512k FFT, 8x AVG
Blackman-Harris 7, 87.5% max overlap
Bandwidth: 20 Hz to 20 kHz
31 multitone TD+N vs level
Dual tone 41 & 89 Hz 1:1 -16 dBFS
16x AVG
Thank you for reporting. I've previously listed K11 as having the issue reported in my FiiO devices compilation post, however that was actually a misedit on my side - @IsaacOscar pointed out KA11 was reported and linked to the source post, and then I just edited K11 on my list instead of the KA11 by mistake. I however accept no blame for this - it is all on FiiO for using similar designations ;) I can't count how many people I saw completely mistaking K11 and KA11.
Yeah, they likely just changed some parameters but the DRE function is still on. I was suspicious of the wording since they didn't mention a switch to turn the feature off. Thanks for confirming.
I really searched hard but I couldn't find any.
The measurements are what you see in the OP. The quote:
The result is simply unaffected by switching between Class H and Class AB.
If you come across a device that is affected, then you are welcome to post your results. The more we know the better. :)
Maybe because completely turning off DRE would increase the noise floor and decrease the SNR/DNR and they don't wanna do that?
Ibasso mentions that on Macchiato and DC04 Ultra user manual:
When DRE is enabled, it can improve SNR/DNR, but may cause multi-tone anomalies (which do not affect the listening experience). When DRE is disabled, the noise floor may slightly increase, and the SNR/DNR may decrease slightly, but there are no multi-tone anomalies.
When DRE is set to optimized mode, it resolves the multi-tone anomaly issue. The noise floor at output levels from 0 to -44dB is the same as when DRE is off. For outputs below -44dB, DRE is enabled, resulting in reduced noise floor.
Seems like TRN has put the silent revision'd version of the black pearl under a different name..
i doubt they are useing the cb5100 since this is the none EQ model
My Luxsin X8 uses CS43198 (8 of them lol) and came with DRE disabled by default. Will be interesting to see how it measures… I wonder if they found some way to reduce the noise floor without using DRE by using 4 DACs per channel. I don’t think it’s the first octo DAC configuration, but I don’t know enough about DACs to know why one would use 8. 2 makes sense… one per channel, but 8? No idea.
Edit: AI says “The primary mathematical reason to run 4 DACs in parallel is to drastically lower the noise floor.” There were some other benefits too, but that’s the primary one.
See this thread: https://www.audiosciencereview.com/forum/index.php?threads/paralleling-dacs.2212/
In theory, paralleling two DACs cuts the (uncorrelated) noise in half, or -3dB.
I measured the new BTR13 firmware for Cirrus Hump and I found some surprising findings.
Typical Fiio software update then?, they can design pleasing looking devices that attract the eye but when it comes to software and device management/apps they are utterly woeful.
I had a BTR17 for a few days but all of the above was true so sent it back and I continue to use my Qudelix 5k (but would appreciate a refresh of the design/button placements
Has anyone recently tested the Jcally JM20 and JM20 Max with the artifacting test? I've heard so many conflicting reports.
I'm glad they've improved the humps, but I'm very sensitive to the artifacting issues present in many of these dongles. Ideally I'd want the JM20 since I don't need the extra power. But I'll go with whichever model is artifact free, if either is.
So it says DRE off but it's not actually off... :oops:
That's unfortunate :<
Edit 1:
I actually tried the CMaj test audio from the main post with my Truthear Pure at a reasonable volume with APTX Adaptive. I can hear like very obvious plastic crumpling when DRE is on (kinda like putting an object on top of a bass speaker as it plays and it creates a vibrating sound), but it's reduced when DRE is off. Not sure how it was in the former firmware - I will have to test when I get the chance.
Edit 2:
I also tested the IEM with the laptop's headphone jack - no such crunchy sound can be heard at a similar volume.
Edit 3:
Tested with the previous firmware, it's actually better than new firmware + DRE on. But it does have some audible crunchy bits, arguably the same as with the new firmware + DRE off.
have someone contacted walkplay to push a firmware update to fix the DRE distortion of the JCally JM20 Pro?
