On the Distortion of Cirrus Logic CS431xx-Based Devices: A Comparative Review
How would this review influence your purchase decision of a device employing Cirrus Logic CS431xx?
  • Going forward I will not buy a device if it adopts any Cirrus Logic DAC chip.
    Votes: 23 11.7%
  • I would not consider any device with CS431xx.
    Votes: 20 10.2%
  • I'd consider a device with CS431xx only if it's been tested free of the "Cirrus hump" distortion.
    Votes: 102 52.0%
  • I don't care about this distortion issue and would just consider the device's other features.
    Votes: 51 26.0%
Not directly related to the CS431xx distortion…
FiiO has released a fw update for the KA15 to address another source of clicks or short silences: v1.1.6 allows the user to turn the power saving mode off by long-pressing the "Volume -" button while connecting/powering the KA15. Restoring factory settings will re-enable the power saving mode.
Note that they also did something about the LS/HS wrong Q-factor, but I think it’s only for the QX13.
The only mention about KA13 seems to be here, and rather indicates the issue is there
i used to have owned the KA13. and i do hear clicking when playing the cmaj test file. when the KA13 isset to NOS the clicking was reduced. the filter selection in the KA13 is abit bugged and doesnt save the filters i select after a power cycle in random.
I ordered a KA15 a month and a half ago and came with 1.1.4 .never had problems with power or power saving.Only problem was the volume button that required to be pressed twice 1.1.5 fixed it.All features work excellently and the android app,only thing is that i feel that sound is a bit boosted ,like applying a VST loudness plug in.I turned desktop mode off and amplifier to H mode and now is a bit better but you have to bring volume a bit up.But its my personal opinion,others might like it boosted.
I've replied to you on the KA15 thread, so that other people looking for information on that device are more likely to find this discussion (and we can keep this thread on topic)
Any news on the iBasso Macaron, Machiato and DC04u?
I know that soon one person will start taking measurements of this device and perhaps publish them on this forum.
Indeed...
According to the manual, iBasso DC04U came with DRE switch (On, Off, Optimized) out of the box.
And, here's the snapshot. (credit: AndyAudioVault)
Just try the procedure except the "-15dB step" since I do not know how to set it, on iBasso DC07 Pro (4xCS43131), with Fast filter, I do not hear any clicking noise along with the low-frequency sound.
So the DC07 pro is on affected with the Cirrus distortion ?I see that Ibasso has no Firmware update for this since 2024 ,does it have a DRE switch or not needed ?
Optimized is new ,no other dongle one has it until this one.
Macchiato, DC04U little brother, already had this “optimized” setting.
DC4U may simply be the op-amp, high-power version of Macchiato (with CS43198 instead of CS4313). Similar to FiiO KA15/Melody…
Yeah, the KA15/Melody with updated firmware basically has "off" and "optimized" options, but no option to go the original firmware behaviour (which activated DRE more agrassively)
KA15 has DRE ON/OFF not OPTIMIZED option
Even if DRE switch were in the works I have no idea how anybody at the ad copy department would have got wind of it let alone drawn it into concept art.
Would be pretty sure DRE here doesn't stand for the DRE switch of the CS chip, even if god knows what it might actually stand for.
Will update if I have one.
Well... it was never an advertised feature unless you consider these background graphics an advertisement. And upon having these pictures pointed out to them, their reaction has been to instruct the team to remove the wording from the pictures ASAP.
I see that the picture from HiBy web-store has been retouched, but not yet in AliExpress.
I believe this part about HiByBlue is still wrong though—you can’t configure W4 with HiByBlue:
I believe it is very much intended for the W4 to be configurable via hiby blue. The question is when--firmware updates have proven to be more difficult than expected, both to write and to flash (users reporting issues flashing the first update). That said, I have reported the current discrepancies to the team. Sorry about this
can the switch from Class H to the Class AB be also enabled in the Hiby Blue app? It was a missing feature from the snowsky melody retro nano. I would really appreciate that to be part of the W4.
I can switch my Melody from class AB to H:
Yes but not for the Snowsky Retro Nano (sorry I wrote the wrong name) which is the competing product to the Hiby W4.
