- Joined
- Mar 1, 2021
- Messages
- 3,271
- Likes
- 6,915
May be you should read at least a few sentences into the actual contents of the first post, not the change log, before complaining? The three-letter acronym is clearly explained in the introduction.This is an awesome thread. But would you mind updating the leading post to with the full name of whatever DRE is an acronym for as part of the very first use?
For example: [7/23/25] ... disabling Department of Real Estate* (DRE) on the ...
* When I do a google search on DRE, that is the only meaningful definition that was returned (along with references to Dr. Dre). But somehow, I suspect DRE in this context means something different than California's Department of Real Estate.
Edit: As a general convention, the full name should always be provided the first time an acronym is used. I realize that it is defined in the text further down the body, but it would be useful to add the definition for people who come across the thread and just read the very valuable change log to get a sense of the overall post.
Can you post some measurements (a spectrogram recording of you playing the major test file?)I ran the tests and the Tempotec Sonata BHD Pro and the iBasso DC07 PRO have this issue. The FiiO KA11 (which should be Cirrus) doesn’t seem to have this problem. On all of these devices, it’s impossibile to disable the DRE
At the moment I don’t have the equipment to properly test it. I’ve always trusted Amir and I’ll continue to do so. I’ll simply avoid looking at Cirrus from now on. The tests I’ve done are "subjective", as I already said.Can you post some measurements (a spectrogram recording of you playing the major test file?)
I've simply used a cable from a 3.5mm output to my computers line-in port (a mic port will likely also work). And that was more than enough to record the distortion.At the moment I don’t have the equipment to properly test it.
Really? What were you listening to?On all my Cirrus devices the issue is very easy to hear and I’ve always heard it, but I used to blame 5G interference from the smartphone.
Didn't you say the KA11 doesn't have the problem?For example, the KA11 is very prone to that when I’m sending messages and the Topping G5 as well when I place the smartphone on top of it and start streaming a track.
For about the same price, you can get the Fiio Tiny, which has more features (e.g. PEQ and a charging port) and no cirrus chip (sadly it's got a bug of its own, but that only occurs when using certain PEQ features).As disappointed as I am, considering the price and its very clean driving power, aside from those very slight issues, I still wouldn’t have a problem recommending the KA11
(there's also the JA11 and Jeizi, which also have PEQ if you are cheap)
Sadly none of them have bean measured by Amir yet, so maybe they do perform worse.
Story of my life (I also own the BTR17 and love it), but at the very least the cheap RetroNano, Melody and BlackPearl have the DRE-Off optionI think the issue can be dismissed by learning to choose Cirrus DACs that at least have the option to disable DRE, or DACs from another manufacturer.
Otherwise, the BTR17 will be more than sufficient for any listening done away from the desk and that’s fine.
I understand if you're too shy to share (I'm very worried about people judging my music taste as I don't listen to the really popular artists...)! I was curious because I've never noticed an issue after years of using a humpy DAC, and I haven't found anyone mention any specific pieces of music with the problem other than the Song of the sisters (by Hanz Zimmer).There aren’t many tracks like this, but they do exist...
Hmm, where you doing a level sweep test? I couldn't work out how to do this correctly as I was seeing no hump, but the distortion lines where clearly visible when looking at the spectrogram of a recording of the Cmajor test file.I tried measuring the KA11 through the microphone input, and honestly I don’t trust it much, but it was clean enough to at least see the upper part of the bump if it were present.
Yeah, I specifically bought a DAC with the switch (the Fiio melody). Alternative non-cirrus ones I looked at with the same features I wanted where more expensive (although they usually provided more power).Seeing that some manufacturers have fixed this through a software update, I think the issue can be dismissed by learning to choose Cirrus DACs that at least have the option to disable DRE, or DACs from another manufacturer
In case anyone's interested, here is what my headphone driver does when I play the C major file at the maximum volume on my DRE-disabled Fiio Melody (which is too loud for me to actually put on my head):EDIT: it seems both the C major and song of the sisters are causing a clicking/ratling soubd ib my headphones (Sennheiser HD 558) (regardless of what DAC I'm using). This doesn't happen with my earphones. I've never noticed anything like this in my years of using them....
I really like my headphone's sound, so I don't want to buy new ones...
Maybe there's something loose inside them that's rattling? I'll open them up and inspect them another day.
I wonder besides testing purposes if all these headphones were expected to play normal in such conditions.Yes probably the can handle momentary sparks but constantly it might damage the drivers and or your ears i guess.A lab or a factory uses other tools to evaluate .Also at extremely high volumes the ear "mechanism" starts to develop fatigue and delivers to the brain inaccurate results.Its ok once for test at home but for longer times its a bit risky isnt it?In case anyone's interested, here is what my headphone driver does when I play the C major file at the maximum volume on my DRE-disabled Fiio Melody (which is too loud for me to actually put on my head):
It looks like this is just stressing the driver too much so I might be damaging it by playing the C major file..
When not on my head, full volume is not very loud (my phone's speaker is louder)ll .Also at extremely high volumes the ear "mechanism" starts to develop fatigue and delivers to the brain inaccurate results.Its ok once for test at home but for longer times its a bit risky isnt it?
Interestingly, I can't seem to reproduce the aberrant behavior of the Apple 3.5mm dongle with my M3 Macbook Air, even though it sounded like some people were seeing the same problems with their Macs. Wonder if Apple has patched it?
edit: guess the distortion is still there in the CMaj test, but very faint compared to the dongle.
There seems to be a lot of extra noise compared to the other measurements posted here, so they may be masking the lines (or it could just be your software colouring the spectrogram differently...)My M4 Macbook Pro:
Extremely faint vertical lines. Has Apple been reading ASR?![]()
I've heard of this problem with other DACs before (that full volume has more noise/distortion); how do I run the test to see if my DACs have it?
Disabling DRE slightly increases the noise level, eliminates increased distortion at certain signal levels (Cirrus Hump), and also restores good linearity.I am wondering if the DRE off ,when applied , if it alters the output in anyway.Yes it cuts the distortion but will it cut anything else ,frequencies ,resolution etc in any way ?
See https://www.audiosciencereview.com/...usb-dac-headphone-amp-with-10-band-peq.64331/ for measurements of the TRN black pearl comparing DRE on and off.I am wondering if the DRE off ,when applied , if it alters the output in anyway.Yes it cuts the distortion but will it cut anything else ,frequencies ,resolution etc in any way ?
