- Thread Starter
- #41
Looks clean:
I suspect it has something to do with changing the amplitude of the signal, the fade-in. In attachment there is a similar file, but this time there's 2 second steady state:
The distortion happens only at the beginning of each segment. Here's JM20 at 0 dB, -10 dB and -20 dB:
View attachment 453370, View attachment 453372, View attachment 453373
and Samsung dongle at 0 dB and -10 dB:
View attachment 453374, View attachment 453375
Done already half a year ago:
JCALLY JM20 Headphone Dongle Review
CB5100 certainly yields interesting results if you want to build your own dongle or make a custom USB-C DSP cable for headphones. The tinkerer in me has awak.. oh, 40 bucks, nevermind.www.audiosciencereview.com
Thanks! I will test the dongles that I have using your files when I get a chance. Basically, your tests indicate that the JM20 still exhibits a similar kind of distortion when a multitone signal's level is monotonically increasing. But based on my results, it can be said that other affected devices with "Cirrus humps" should produce distortion whenever they meet the signal (in a certain range of levels) including the case of the signal level being steady. Right?
In fact, your previous tests using the soundtrack in the RAA article (Dune Sketchbook Soundtrack - Song Of The Sister, Hans Zimmer) suggest what I just said. See your results below (copied from your previous posts).
Tanchjim Space (full, -6 dB, -12 dB, -18 dB):
JCally JM20 (full, -6 dB, -12 dB, -18 dB):
Samsung dongle (full, -6 dB, -12 dB, -18 dB):
Careful, comparative inspection of these three outcomes tells us:
- It is very likely that the Tanchjim Space produces the same "Cirrus Hump" distortion that my review showed.
- The JCally JM20 still shows hints of similar distortion, but it is much lower and less frequent.
- The Samsung does not produce the same kind of distortion but, as Amir's test showed, its noise performance is substantially worse.
I will post my recording tests of the dongles using these tracks.
BTW, what software did you use for recording and drawing spectrograms? ALSA on Linux?
