I never claimed anything whatsoever about windows resampler. Nothing about it's quality, no claims about voice meeter being better, and no claims about windows being bad at anything in any way; other than problems with some APO's showed in the linked thread above.Your setup, voicemeter into a VM, is novel and any quality improvements need to validate before making credible claims. Simply assuming that the quality must be better is a sure way to introduce unforeseen quality degradations. The performance of Windows resampler on the other hand has been well studied and serves users even with high standards.
The only 2 claims I've made is after testing a second time (with higher volume and a more quiet room) I could hear the distortion in the C Major track provided in this thread on my moondrop dawn pro. Also that I didn't have any noticeable audible sampling artifacts from voice meeter. I guess that second part is what you have issue with?
My setup is not novel at all. VM was abbreviations for voice meeter, did you think I meant virtual machine? Oops, if that was the case. My setup is basic. windows 11 ->Voicemeeter -> dawn pro -> headphone amp-> headphones/IEM's.
I think this is mostly just a miscommunication.
Thank you, you should be able to use voicemeeter banana without even doing the trial. The banana version is freeware and the potato is it's paid counterpart unless something changed very recently. If you want to know my specs I'm using 192k and 1024 buffer after learning about the NOS 50k oddities you found. Before I read this thread I was using the default settings.When I get a chance, I will run a quick test of the Voicemeeter's upsampling effect as it provides a 30-day trial.
