On My New Topping DX3 Pro
Androxylo
Does DX3pro sound better if connected to a separate pre-amp instead of using it in preamp mode? What about external passive preamp, like Schiit Saga?
SEKLEM
Indiana
It should get you a better signal to noise ratio by going direct to the amplifier, essentially nothing gets in its way. The DX3 does approximately 2v which is enough to drive most amplifiers to full output, so headroom shouldn’t be an issue. The passive pre would be unnecessary unless you intend to run the DX3 in DAC mode with fixed output to safeguard your amplifier from sudden full output if you make a mishap with the remote or press the knob on the DX3 one too many times.
o2so
Sydney, Australia
Hi, is the volume controlled in the digital domain when used as a preamp? And does this affect sound quality at low volume levels compared to an analogue preamp, or is this another myth?
SEKLEM
Indiana
Digital domain I believe. It seems to be excellent to me, at low levels and high.
