honn
- Joined
- Nov 8, 2018
- Messages
- 98
- Likes
- 61
Hi all,
So, since an objectively good DAC is transparent and shouldn't add anything to the sound reproduction, among the top 10 DACs (by SINAD) reviewed on ASR, say between the $11,500 Mola Mola Tambaqui, the $750 Topping D90, the $500 Gustard X16, and, just in case, even the only $130 Topping E30, is it then correct to say these about them:
1. that there won't be any difference in the humanly audible sonic performance among them? (say psychological biases from knowing the prices, looks, etc, are removed through a properly designed and executed blind-test control).
2. that the relevant differences among them are only prices, aesthetics, material/build quality, features/connectivity, etc, everything else but the audible sound quality?
3. that if the audible sound quality and value are your only priorities (I know most of the times it's not the case but hypothetically), then you should always buy the Topping E30 than the 8,800% more expensive Mola Mola DAC?
Thanks!
Thanks!
