restorer-john
What 20 kHz? My frequency response measurements go up to 200 kHz:
At a measly 5 watts Amir. Let's not play games here.
Rule of thumb is used to give reasonable performance without investigating how far each parameters can be pushed. 100khz bandwidth for class A amplifiers will most certainly give pretty good distortion under 10khz. But will including 10th order input filter to filter out any signal over 20khz affect performance? If done right, of course not.What are you going on about??
And I'm sorry, this is just plain rubbish.
What, you want to make it really easy for any DUT?
This is right on the money. It's a concerted attempt to control the narrative and undermine many decades of superlative design and countless luminary engineers' research and development. You will meet opposition here by fanbois, vested interests and sonsumers of the koolaid, but stay the course.
Do you really know how to do measurements? Frequency response is generally considered to be small signal measurement. Normally it's 1V at output or 50mV at input or somewhere in that order. Then do the slewrate test for small and large signal.At a measly 5 watts Amir. Let's not play games here.
There is absolutely no need to have high power at high frequency. Flat to 20khz is good enough or including phase then 40khz.
Hint: The frequency range at which an amplifier can deliver its rated power (half power if you want to be kind) at a specific THD (usually 0.1%). Most decent amplifiers in the 1970s rated out to at least 40 or 50KHz...
Here's an ancient Pioneer SA-708 (late 70s design) tested by me way back in 2009 at 76W@8R (rated 65W@8R) FR swept from 10Hz-20Khz just under clipping.
Not so bad, I think.
"These days it is unimportant. Who cares?"
Some more than you, it seems.
Because I ask for the product, being it instrumentation or audio, to work flawlessly in the frequency range at least one order higher (10x) than is the supposed bandwidth of the signal processed. .
Understatement.
What I find absolutely hilarious, is the same people who espouse "High Res", high sampling rate, DSD, wide bandwidth, ruler flat sources, and line level processing, are prepared to dismiss the same ruler flat requirements in their power amplification.
There's no free passes in high fidelity, no matter how thick and sweet-smelling your smoke screen is.
Re your question of squares, I have already explained that the step response completely describes transfer function of the linear system, because impulse response is a derivative of step response and amplitude and phase response can be calculated by Hilbert transformation of Fourier transformation of impulse response. This forum calls itself "science", right? Step response quickly shows possible issues and possible stability issues, as it does here. 20kHz amplitude spectrum shows a little.
Understatement.
I find all this defense of narrow band 20kHz measurements as manufacturer's protection only and a part of marketing strategy. This is a must for contemporary class D technology.
There are no stability issues. with these amps.
There is something wrong with that amp if thats what it does, thats not how the NC500 behaves.At a measly 5 watts Amir. Let's not play games here.
How about capacitive load, like some ESL speakers.
HYPEX NC400, no LPF before the oscilloscope, 52.3kHz oscillations, 3.41Vp/p, about 1.2Vrms
John, just for fun, this are plots from this amplifier
https://www.audiosciencereview.com/...vintage-kenwood-ka-5010-amplifier-clone.9902/
at 1kHz near clipping and then at 100kHz, both wit 4ohm load:
But, you know, these days it is unimportant . Who cares? However, this linear amp is fully competetive even in THD and SINAD . End does not send tons of HF 440kHz rubbish and its multiples into the air. Who cares? EMI pollution is a standard, nowadays.
