Vinyl is like Ben&Jerrys you can have and enjoy any flavour you like, as long as the record rotates at more or less the correct speed, it is a movable feast.
I take exception to this comparison. Ben & Jerry produces among the best ice creams commercially available .. Blind tested .err... TastedVinyl is like Ben&Jerrys you can have and enjoy any flavour you like, as long as the record rotates at more or less the correct speed, it is a movable feast.
I've never heard a defect caused by a turntable unless it was super-cheap or broken. I've heard rumble (or other "mechanical" or motor noises) from a BSR or Garrard "record player" and I've heard speed problems (slow or wow) from a worn-out belt or drive wheel.
And I've heard different frequency response from different cartridges. Or at least I think I did... I never had a setup to properly A/B or ABX.
On the other hand, I've never heard a perfect record.
Easy, try lifting them.EDIT- ooh - and would anyone be able to tell the difference between the £12,500 Naia, and the £360K K3 in a blind test?![]()
Have you ever heard a perfect CD, SACD, stream, reel to reel, speaker, etc?I've never heard a defect caused by a turntable unless it was super-cheap or broken. I've heard rumble (or other "mechanical" or motor noises) from a BSR or Garrard "record player" and I've heard speed problems (slow or wow) from a worn-out belt or drive wheel.
How would you know it was perfect unless you were in the studio at the time the recording was made?Have you ever heard a perfect CD, SACD, stream, reel to reel, speaker, etc?
I am yet to hear perfect anything in Hi Fi, speaking only for myself.
It all falls short of the goal, so I hesitate to run with the *sniff* posts about any one type of playback or gear.
I believe you when you say you've heard different cartridges sound different from one another, that should not be controversial or agitate the A/B or ABX robots at all!
Depends on your definition of perfect.Have you ever heard a perfect CD, SACD, stream, reel to reel, speaker, etc?
If that's the criteria, fine by me, 100%...none are known to be perfect, so we can relax and enjoy ourselves without the runaround about some poor guy thinking he has to do DBT to pick a phono cartridge.How would you know it was perfect unless you were in the studio at the time the recording was made?
And what are those components used in anti ballistic missile defense system? 1/4 20 screws and locktite.
I'd love to hear the circumstances, DBT, A/B, A/B/X, of course. Otherwise, sighted bias must be invoked.Depends on your definition of perfect.
I've heard digital sources produce an audibly perfect representation of the encoded music.
Almost all digital sources do thatDepends on your definition of perfect.
No, it doesn't. Measurements are sufficient to show that noise and distortion from a digital source are below the level of audibility.(Actually, I believe you, but that steps into the realm of subjectivism.)
With sighted listening, you can hear that there are no errors...that's pretty awesome! I commend that! (I'm still thinking there is some subjective sighted event happening, but I take your word for it. Hearing that perfection is the epitome of the hobby, after all.)No, it doesn't. Measurements are sufficient to show that noise and distortion from a digital source are below the level of audibility.
If there are no errors in the delivered data (you can hear it if there is), and the DAC has such low levels of noise and distortion, the result is audibly perfect.
Errors in the digital stream that are not corrected are usually very apparent to most listeners.With sighted listening, you can hear that there are no errors...that's pretty awesome! I commend that! (I'm still thinking there is some subjective sighted event happening, but I take your word for it. Hearing that perfection is the epitome of the hobby, after all.)
Which audibly perfect speakers are involved?
This is what I call "end point" fidelity. Nowhere to go!
I like all formats, but have never heard audible perfection.
