OLLO S5X Headphone Review
Rate this headphone:
    Votes: 33 25.0%
    Votes: 61 46.2%
    Votes: 27 20.5%
    Votes: 11 8.3%
The new X1 raises an interesting question for ASR in terms of a possible review. Should it be measured and assessed as it is, i.e. without EQ. Or should it be measured with the included Harman curve activated? Since Harman is the target value for Amirmn's measurements, shouldn't it also be measured with that target curve activated? According to OLLO, you achieve a much higher accuracy with an individual curve than you could ever achieve with the "hardware" alone. As far as I know, this is the only headphone that comes with individual eq curves for several different target curves. This leads to another question I think. What is the ideal headphone? The one that is best suited to adapt to different target curves, or one that is already tuned beforehand to correspond to a certain target curve (which is then not flat) in the initial position.
Comfortable fit, not warm on the ears, no seal issues, low clamping force, easy to drive from all sources (lowish and flat impedance), lightweight, flexible cable that is non microphonic, multiple connectors that fit on a small connector so all sources can be used, low distortion even at high SPL, adjustable target frequency response to taste or known references. Sturdy build, nice looking.
Does not exist yet but at least we can dream.
I thought Sonarworks also sells headphones with individual EQ for headphones they sell or get sent in.
It just isn't Harman target nor on an industry standard fixture.
Thanks a lot for your review. Because it takes time and energy, especially with clients like that.
I voted poor.
If I may ask, it would be to correlate the "performance", which is deficient here, with the price. I have 4 headphones, but they rarely exceed $15 (in major brands like Philips).
I voted poor.
In that case all headphones are poorly rated that exceed $15.-... at least for you.
One can ask the question if a headphone is poor if it exceeds $ 15,- or that you are merely judging a headphone to your perception of VFM (value For Money) ?
I don't think it changes much actually. ASR reviews for consumers, and the mass of consumers can't be expected to be running Sonarworks or AutoEQ.
Professionals are expected to understand the FR and distortion measurements and make up their own mind whether headphones suit their needs or not. For a subset of professionals, the ideal professional headphone would indeed be the smoothest FR curve and lowest distortion, because of the ability to get to any curve you need. But I will say that for also many pro's prefer an ideal curve (for them, Harman or otherwise) out of the box so that they can take their headphones to any studio, or simply buy what everybody else around them has. Practicality matters.
So this Ollo approach is only relevant to the (I believe) small set of consumers and professionals who do run Sonarworks/AutoEQ/PEACE.
It is aimed at professional usage. (production)
The VFM is important of course. Heard a lot of expensive headphones, well... It's like for speakers.
The sound is a little different, not better and far from night vs day.
Probably my hearing, which I measured last year and has deteriorated a little. But even when I was young, I had questions...
But no doubt you have some experience that you could share with us?
I have recorded and worked a bit in studios and radio stations, I can assure you that apart from the transmitters or consoles and tape recorders, for the rest if there was a way to get something cheaper (if still vaguely solid), they didn't bother!
already did a year ago....
and some other experiences too:
According to OLLO Audio, the EQ are not provided for Sonarworks etc only. The settings are provided and can be used in any EQ,. The settings are provided and can be used in any EQ, for example in ROON or Equalizer APO. So it should not be any more complicated than any equalizing suggested by for example amir.
From OLLOs website:
"The plugin comes in AU, VST and AAX format for Mac and Win users and is also available in standalone version. The calibration data file is in XPS format that enables manual export of exact EQ values to any 3rd party EQ plugin or DSP enabled hardware; for example: RME TotalMix, Neumann Mission Control, UA console and others.
Calibration includes:
  • OLLO USC II plugin (AU, VST, AAX)
  • OLLO USC II standalone app (Mac and Win)
  • USC II calibration data file compatible with Realphones and Waves Nx
  • Open data file for easy export to any 3rd party EQ or DSP enabled hardware"
According to OLLO Audio, the EQ are not provided for Sonarworks etc only. The settings are provided and can be used in any EQ, for example in ROON or Equalizer APO. So it should not be any more complicated than any equalizing suggested by for example amir.
You’re right, I thought it was hidden. But you can simply open the file in notepad and see what settings it has. Good news, and in that case the point stands
Yesterday I put on my Dan Clark AEON Closed X. These used to be my absolute favorite headphones, but since I got the OLLO S5X I've been using these almost exclusively instead. But yesterday I thought I'd listen to music with my AEONs again as a change. I lasted three songs before switching back to OLLO. o_O I now actually have a hard time understanding what it was that I liked so much about AEON.:oops: If the X1 is properly tested by someone and if it is a significant improvement, I will almost certainly get this new OLLO. However, the AEON is much more comfortable on the head. I have to admit that, although I never perceived OLLO as directly uncomfortable.
It seems S5X and the new X1 will sound very similar. I wonder if the difference will be noticeable at all.
If it is, I’d expect it to be minimal. If there was a noticeable (i.e. non-trivial) difference, that would imply that at least one of them is not that useful for its intended purpose.
I was just on DIY-AUDIO-HEAVEN (https://diyaudioheaven.wordpress.com) and read solderdude's review of the new OLLO X1. Thanks @solderdude for the review. As one might suspect, the difference in sound between this and the predecessor S5X appears to be minimal to non-existent. However, if I understand it correctly, it is a clear improvement in terms of comfort and of course the calibration files that come with it. Those who want Harman-tuned sound can now easily get it. I would love to have this headphone, but doubt whether it's worth the price to upgrade from the S5X.
Looks pretty similar to the HD490 with producer pads which I really like so that is cool / makes me feel like I don't need more headphones :p
There is a new model from OLLO headphones on its way. They call it the R1. This time it is a closed headphone designed for monitoring in studios and other environments. According to OLLO-audio, it will have an increased level in both the lower and higher frequencies. This time, in other words, it will not have a “flat” frequency response like the X1. The price is 399 Euro.
About Ollo. I have to say that X1 is something that I still am quite excited. Sometimes I really do feel that I am not wearing headphones at all, but listening to good monitors (and sometimes better than the monitors themselves, even expensive/good ones, like bigger Genelecs). R1 I will definitely skip. X1 is semi-openback, and I think that is a quite good compromise on day-to-day use. The open-back would be nicer in someways (especially if you use them to video conferencing too), but I am definitely not going to check out any closed ones. There are uses for them (e.g. you don't want to disrupt others or want to isolate yourself in noisy environments).
This I agree. X1 needs in my opinion some boost on lower and high frequencies. If you have any eq, even bass/treble, I think you can get good enough in most situations. There is no clear one good choise (and thus you need to kinda avarage out) as it depends a bit on track (everything that comes from the studio may not be good/perfect/to your liking).
