The house is a rental, so I'm reluctant to invest in the electrical at this point. The outlets measure about 117V, which I'm assuming is also what's coming into the panel. I have my computer on an APC Pro 1000 S to protect it from all the mess.
I have my headphone set up on a zero surge 8 outlet box, but I'm curious to check out the SurgeX strips that offer the under/over shutdown.
The panel is relatively new, with 15 and 20 amp breakers and a 200 amp service breaker, also a 220V circuit for the garage and another 200 for the dryer. The wiring inside the house is that old ceramic tubing and braided cable type. I met a guy I bought some furniture from in a similar house and he said when they moved in and installed security cameras that the cameras were fried within a few weeks.
I know things like motors from the washing machine may not just create sag but can induce voltage spikes, so my concern isn't entirely sag considering the washer makes every light (both hard wired to the ceiling and desk/floor lamps) blink.
In theory a PS Audio power regenerator seems like a good idea but it seems that Amir "debunked" these as creating more noise floor? I didn't get to digest that whole review.
Another idea was to create a mini offgrid solution, where I have a few large batteries hooked up to a AC converter. Then I could look for a particularly good AC converter vs whatever is default on your standard UPC or off grid package units like GoalZero . My APC Pro 1000 does have an improved sine wave technology over the cheaper models, but I wouldn't know if somethign like this would be capable to properly feeding a hifi system.
117V in itself is not terrible, the spec is 114V to 126V.
I think you are on the right track with a power pack like Goal Zero, Jackery, Bluetti (my choice), Ecoflow, Anker, or a reputable product available in your area. Check their UPS switchover time, the new Bluettis are very fast, claimed <1 millisecond. A power pack "pure sine wave" inverter is not that pure, so run it through an Eaton Isobar at a minimum.
Think through your grounding situation, which with "knob and tube wiring" is probably non-existant. At least you can connect some cheap solar panels to the power pack.
The old "knob and tube wiring" can be safe, other than not having a ground. If they replaced your outlets with 3 prong, get an outlet tester. It will show if the ground prong is even connected. It is required that the meter base, main panel, and sub panels be earth grounded for safety. Some US states are lax on electricians and cities lax inspecting electrical work.
In many towns, the local electric company will come out to inspect what you describe for free. The magic words are "I want to be sure there is not a safety problem" after describing what you observed here.
It may be the wire from the pole to your house or the meter base are not sized properly, or the wire gauge to large loads, like the dryer, water heater, or furnace are not sized properly, causing the flickering. It is also possible there are high impedance bad connections beyond the breaker which are a fire hazard.
I would also be sure your renter insurance is comprehensive up to total loss, document all your belongings, be sure you have smoke alarms with up-to-date batteries, and suggest familiarizing yourself with every word in the rental agreement and local renter law.
All that said, enjoy your music!
(I am not a licensed electrician and this is not professional advice)
