Count Dacula
- Joined
- May 24, 2023
- Messages
- 577
- Likes
- 340
Trying again to find the right forum.
Any advice on repurposing my beloved 2x8" sealed 3-way KEF C75s into 2x8" mini subs for my various minisystems?
These guys owe me nothing, but it would be cool to STILL use them after 35 years. However, this would be a tricky rebuild, or barely worthwhile, to replace one side mid-hi with a junkyard part for $100, only to yield two old obsolete units that still need new ferrofluid, et al. I have plenty of other newer speakers, all with varying sentimental value.
So, since I already have 2 good 8" KEF woofers, can I just brew up a unit with a small bass amp? like...
My question is about the #2 unit. Since I already have two brand new Parts Express 8" woofers, already here (somewhere) from another failed project, exactly how should I use them?
Ohms are unknown, I suppose the KEF B200s are 8 ohms each. So, should I make two different cabinet loads, one KEF and one with the new Parts, or Homebrew it with one of each, and let the amp figure it out? I don't plan on using them together, at once. It's possible, but not an objective. Ill see if one unit is better than the other too...
I think it's a good question, and hopefully meets the criteria for a post.
If those Parts Express are 4ohm, I better not put them together. I think they are "home" 8 ohm though.
Same thing for the Sealed cabinets. I assume the KEF drivers are ideal for Sealed, but will the new ones be ok if they are "for" Bass Reflex? How can I tell from volumetric specs??? Does it really matter if I put B-R in a Sealed cabinet? Should I mix them up, one and one, for any of these reasons?
Fosi Audio M03 200 Watt TPA3255
Right? Just enough power for 2x8" drivers in parallel. I'll just attach the thing like a wart, lol. The low/fat tower cabinets are such a nice form factor too. It's ideal, imo.My question is about the #2 unit. Since I already have two brand new Parts Express 8" woofers, already here (somewhere) from another failed project, exactly how should I use them?
