What are these measured latency differences? Do they appear even without AVDSP firmware?Has anyone had success dealing with the variable latencies of the dac8 across different channels? Maybe it doesn't matter much for bass management, but it's a problem for active crossovers and DRC.
Here's the issue I'm running into with Okto, that seems to put it out of the running for an Active XO. Quite different results from three replicates.
View attachment 466224In the case of the front left bass at 4.90ms in the first measurement and then 0.52 in the 2nd measurement means it is off by 4ms or 4 feet. Unfortunately, this affects both the timing and frequency response. And there is no way to know if any of these are actually correct. Seems like this has come up as an issue in the past too, with Okto. Have the 1.60 firmware. @fabriceo, any ideas on this? Haven't received any response from the Okto email, so appreciate it!
That other users had this same problem with the Okto, which was also resolved when moving to a different dac, seems like replication.
What leads me to be fairly confident this is due to the Okto, is that I've used the same laptop, mic (UMIK-1), audiolense version, amplifiers and this same exact process to setup a different pair of speakers in that same room. Had excellent results and - no delays as are now occurring. The only difference was swapping the dac (and this is an active setup). That other users had this same problem with the Okto, which was also resolved when moving to a different dac, seems like replication.
SoSingle channel USB mics like the UMIK-1 are not capable of accurate timing / phase measurements. See warning below from the VituixCAD measurement guide.
audiolense 6.21 on a windows 11 laptop, with USB cables to okto and Umik-1 microphone.
Hello - talked with a few other individuals who have had exactly this same problem. The solution has always been to swap to something like the motu with a common clock for the mic and dac. It's not like I want to move away from the Okto, but it's not providing the required results at the moment. The motu should arrive Monday, so I'll see if that does the trick for me as well and report here.
Appreciate the very kind offer @fabriceo - my setup is very simple to replicate - audiolense 6.21 on a windows 11 laptop, with USB cables to okto and Umik-1 microphone. Have you incorporated audiolense in your testing of this issue?
