Not with TAD drivers then1,100 Euro Best In Class DAC with 58,000 Euro speakers! Time to work on affordable, high performance speakers!
we just found our chief smelling officer
My alternative is the OCTO8 + having my DDRC24 moddded to output SPIDF through two channels.This seems to be an exclusive and expensive solution but impressive.![]()
The required analog output stage between both is radically different, if I recall correctly Okto is not too interested in making a 9038Pro one, the 9028Pro hits the audio analyser's limits anyway what more could 9038 bring besides placebo?Any idea why Okto chose to use the ESS 9028 instead of the 9038PRO?
Exactly9038 presents analog stage design challenges afaik, it may have a better potential but in reality it's hard to beat 9028 numbers, so why bother.
Sure, but think of how much better they could do with a 9038PRO.9038 presents analog stage design challenges afaik, it may have a better potential but in reality it's hard to beat 9028 numbers, so why bother. In fact DAC8 already performing better than all 9038 DACs we've seen here.
How much better.. like, half a percent better? No seriously, this is already the best of the best. No need to feed this curiousity, Okto works perfect as an 9028 DAC if you want a worse performing 9038-based one by all means, get that and save some money.Sure, but think of how much better they could do with a 9038PRO.
That’s almost like saying, what does 122 SINAD bring to the table over 115 SINAD. In practical terms, nothing. According to your logic, then why even do it?The required analog output stage between both is radically different, if I recall correctly Okto is not too interested in making a 9038Pro one, the 9028Pro hits the audio analyser's limits anyway what more could 9038 bring besides placebo?![]()
The point is progress.How much better.. like, half a percent better? No seriously, this is already the best of the best. No need to feed this curiousity, Okto works perfect as an 9028 DAC if you want a worse performing 9038-based one by all means, get that and save some money.
I think your solution is very elegant. The custom USB cable in the back is almost invisible and non obstructive. In an ideal world both boards would be able to communicate inside the chassis, but I think adopting a standard hardware like a Pi (that can be easily user customized, replaced and possibly upgraded), and choosing a no sonic compromise solution (with DSD support) is brilliant.The external USB jumper is a necessity, because the standard format Raspberry Pi does not have USB routed to its onboard header. However, it is a plug-and-forget thing and a small price to pay for making it possible to accommodate a standard-format Raspberry Pi.
Did you miss the post where it was already shown, Amir's analyser cannot measure further than the performance seen here?That’s almost like saying, what does 122 SINAD bring to the table over 115 SINAD. In practical terms, nothing. According to your logic, then why even do it?
Progress would be a $99 DAC with those specs.
The 8 channel one is cheaperAbsolutely. But at least to half the price first.
The thing about the pricing for this stereo DAC is that it is totally out of whack with competition of which there are plenty in the 2-ch market, granted with not as good subjectively in industrial engineering and aesthetics for a traditional audio stack. It is like a well-crafted watch that you pay a premium for although cheaper ones will keep time just as well. So, it is a little bit of bragging rights involved as well. Would there be equal excitement if it was 5th or 6th down that SINAD list with no impact on audibility?
On the other hand the 8 channel Octa8 Pro has almost no competition and priced not much more above this.
I am very curious about the make of your headphones...or are you connecting to a HiFi...?
Don't feed the tr0ll....Please prove your results by starting a new thread and showing measurements.
Yes, they started their development with the ES9028 when the 9038 was not available yet. When it came available they assessed any benefits of this later DAC chip for their design goals. The result was there where none. Except a higher current output of the 9038PRO both DAC chips are largely identical anyway. And only the 9038PRO has the annoying so called THD+Noise hump which is not easy to get rid of.Any idea why Okto chose to use the ESS 9028 instead of the 9038PRO?
