Not denigrating this obviously top notch device
And signal-clocking via AES can be fine
However IMO soon as you need more than 8 analog output channels (and/or adding ADC) BNC WC sync is THE way to go.
There are SO MANY top notch format converters, interfaces etc with that basic infrastructure, dare I say better value for those use cases?
Better than trying to stretch what is yes a fine DAC, into something else that it wasn't designed for.
I am trying to understand this. Spelling it out for clarity. Lets say all 16 AES sources has 1 clock source. 2 Okto's in pure USB and 16 AES setup, would have some device/card transfer data from 16 AES into your pc/mac using some interface and then output to the 2 Okto's in pure USB. In USB/AES mode that device/card that inputs 16 AES (8+8) are the 2 Okto's correct? Both require 2 USB connections from the PC/Mac to the Okto to output data. And the latter is the issue. Is it becasue in the 2nd case there are 2 USB device's used to input the AES data into the pc/mac?...
As such I would absolutely use two Oktos in Pure USB mode from a 16 channel AES source. But I would not use two Oktos in USB / AES mode from a 16 channel AES source.
Michael
SMathews
So in your previous post did you mean pure AES not pure USB?Pure AES
Both devices are clocked via AES input, all input to output routing is done in Okto itself. Latency is Okto intrinsic delay which is constant for a given filter.
USB / AES
Both devices are clocked via AES input, software is required on USB host to route AES input to analog output. Latency will be variable between devices due to USB host variability. This means outputs will be synced between the two devices but delay between them will be variable.
Pure USB
Devices are clocked by their own internal oscillators. Two USB devices can never truly be clocked synced. There are software methods (MacOS aggregate device) that do an OK job of maintaining sync between two devices which are acceptable at lower frequencies, but not acceptable at higher frequencies. USB host restarts will also slightly change the relative delay between two devices.
Michael
Ah, yes. I was confused why you were talking about Pure USB, but didn’t realize I had mistakenly typed that. I’ve corrected the post.So in your previous post did you mean pure AES not pure USB?
SMathews
Had my Okto for a couple of months now, here it is in situ sitting below my multichannel Roon end point and above my Topping LA90D speaker amp and Pre90 which is acting as interface between the Okto and a pair of single ended subs.
I have been able to set a properly engineered crossover between speakers and subs using Roon and REW and it all works seamlessly; I've also been able to use the Okto trigger to control a relay that turns on the Pre90 as soon as music plays, and turns it off when the Okto powers down (the Pre90 doesn't have a trigger of its own). Very happy with my purchase. I don't see the electronics changing any time soon, unless something breaks, so having built the Roon endpoint myself, I need another project! Just so happens that Modushop, where I got my Roon enclosure from, also supply Okto with some of their enclosure, so it matches perfectly!
