Vasr
- Joined
- Jun 27, 2020
- Messages
- 1,409
- Likes
- 1,950
Hello Vasr,
OK, now I understand that you would like to have some switching/distribution mechanism in speaker level signals after the amplifiers.
Thanks! You have done the hard work of confirming my intuition about signal degradation. It is not that I want to switch at speaker levels, but there doesn't seem to be a solution if two amps need to drive the same set of speakers.
The alternative that will work is to get a stereo power amp with gain control and integrate that into HT by gain matching just like one would with a sub (most of which come with a gain control) in the analog domain. Then use the Stereo amp for HT as well. I don't know of any good stereo amps outside the pro world with gain control.
The other option to use a stereo amp without gain control for HT is to buy a stereo amp that has equal or greater gain than the HT amp and do the correction in digital domain so you are only attenuating the L and R going via the stereo amp to match the output sound levels rather than match the gain between the two amps. Otherwise, it would potentially digitally clip if it was the other way around, especially if the gain difference was significant.
But not sure input sensitivity wouldn't be an issue here and reduce the dynamic range for the L and R with that attenuation correction.
Will research more. In any case, this is going beyond the Okto scope so I will end further discussion on this here. Doesn't look like there is an off-the-shelf solution for the switching.
