@OCA ->YT-> Convolution with Inversion - WindowsPC + eqAPO + usb
Darek K
Hi.
My question is about the pdf at
"However, this program (EqualizerAPO) is for PC only and you will then need to use “Java” drivers instead of “Asio4all” in REW. Java drivers will work just fine unless your computer is connected to your amplifier through HDMI" - does this mean that using a USB cable is not recommended ? Does it have to be HDMI or can there be an s/pdif cable?
What if I can install Asio4all on my computer ?
Can I use Asio4all instead of Java ?
Greetings.
Darek K
OK.
Because my english is rather mine than english, I may have misunderstood the sentence "Java drivers will work just fine unless your computer is connected to your amplifier through HDMI".
My new understanding is "HDMI is not recomended, all other connections (usb, optical s/pdif, electrical s/pdif) are ok. <- am I right ?
