Need some help. I've completed the A1 Acoustix calibration with the OCA script last night. I have a AVR-x4800H running in 5.1ch/Zone 2/3 configuration with the Surround channels turned off in the web control for a 3.1 setup. I've previously run Audyssey and also completed the manual configuration process using OCA's video using Multi-Eq android app to load to the receiver. OCA reported the Amp Assignment as FL, C, FR and SWMIX1 which is correct
I ran the A1 Acoustix using 1 position (MLP) and 8 sweeps to create the OCA file for loading. This all worked after loading to Speaker Preset 2
Yesterday I completed a 3 position around MLP and 8 sweeps to create a new OCA but I can't get this file to load as the Acoustix script is complaining about Amp Assignment. I've made no changes to Amp Assignment - I'm still running a selected 5.1ch/Zone 2/3 setup as the first load. I've tried turning on/off the Zone 2 and Zone 3 loading in each configuration (i.e. 4 times) and still get the same error message. I've also tried loading to Preset 1 again with the same error message.
I was going to try and just retake all the measurements after doing an AVR settings in the Acoustix main menu but now I've got the dreaded "Audyssey mic failure"occurring with SW volume reporting below level and FL speaker not found. Tried to rerun an Audyssey calibration using the Receiver and Multi-EQ app but get the same results. Looks like the Audyssey mic has failed.
Does someone know what the OCA script is looking for in the "1" vs "0" of the error message. So I can make the receiver go to this configuration and load the Acoustix calibration run I just completed. I need to sort out the Audyssey mic issue with Denon as this is a new receiver from them directly via Amazon fullfilment.
On an alternative note - If someone can outline what the A1 Acoustix script expects to have completed in REW set of waveforms processed manually. I can retake my measurements using my miniDSP UMIK-1 and REW to have measurements created for and Acoustix processing via the main menu. But I don't want to do all that processing and end up with the same Amp Assign error.
