Very cool but where is sub 100Hz?Revel F208 or Kef R11 are good obvious choices. A less common choice, but with great measurements and high praise from James Larson at Audioholics, and a very cool modern industrial design, is the Definitive Technology Demand D15 (or D17 assuming it measures as well or better). All of these appear to measure better than the VR-5. View attachment 138116
What is your definition of 'full range'? My main thought whenever I hear this is to factor in a subwoofer (or two)...
Since you didn't specify a +/- dB, every speaker ever made qualifies.My definition is 20Hz-20kHz in-room without a subwoofer.
Ideally +/-3dB
Ideally +/-3dB.
The published specs of my VR-4 Gen III HSE speakers:
Frequency Response: 20-30 kHz, +/- 2 dB, 16 Hz-40 kHz –6 dB, (+/- 1dB at midband).
While I know those specs are likely exaggerated I can tell you they have no problem hitting low bass with authority.
Published specs for the VR-5 Anniversaries:
Frequency Response: 20Hz-70 kHz, +/- 4 dB (30Hz-30 kHz +/- 2 dB)
