O-NOORUS D3 - TPA3255 Amp with ES9023P DAC, NJW1194 Vol Control with remote
yeah the Chinese should be praying every day to Texas Instruments for delivering the TPA3225
about psu rolling on integrated amps... someone tried this on some brand of chinese integrated and it fried the unit
on a Fosi V3 all the power is going into the power amp stage but these units?
ehh... i dont know about Chinese engineering here... it sounds like its feeding more power to the DAC etc. and boiling that circuitry so I always am wary of psu rolling on these
Product pictures says up-to 50v psu usage, but I can’t clearly find in internal pics the caps ratings.
In any case, a 36v 6a psu should easily get to 50watts per channel into 8R load.
I kinda have a good eye:
It says 63v. It most be the same Nippon Chemi-Con capacitor used in V3
My old eyes couldn’t get it, thank you.
So one can use 48v psu for maximum power of the amplifier.
Is it popular to use XU316-1024-QF60B-xcore to replace ALC4050?
XU316-1024-QF60B-xcore outputs IIS up to 192khz.
I don’t know whether it’s “popular” or not (is it what you mean?), but XU316 and ALC4050 are not exactly equivalent: ALC4050 is an audio codec, with a bunch of integrated features (USB bridge, DAC/HPA, ADCs, EQ, ANC, etc.), XU316 is a (high-quality) USB bridge with multi-cores processing units.
In the case of the O-Noorus D3, I don’t think we know which of the ALC4050 features is used. You’re not thinking of replacing the ALC4050 with a XU316, are you?
ALC4050 only uses USB bridge. Yes, I want to change to XU316.
I have received an O'Noorus D3. It would be great to see this amp put through the dyno testing. I'll post my impressions after a bit of time with it.
In December I ordered the D3 from https://www.audiophonics.fr/en/inte...55-bluetooth-50-2x130w-4-ohm-red-p-18231.html.
Upon arrival, the power supply unfortunately died: its' output showed 3.5V.
When contacted about this, Audiophonics arranged for a replacement immediately and shipped by UPS.
Didn't have much time to spend with the D3, looks and sounds good though.
But this was more about Audiophonics' professional and fast reaction, thought they deserve to be mentioned in this thread in a positive light.
Edit: the amp is on half a day today, lowish volume (22-23 on the display), and the enclosure is getting quite warm. Could be a concern long-term.
It is normal for the case to heat up. Because the case is used instead of a radiator (there is a photo above, there is no radiator inside, and the chip is cooled by the case)
How do you like the amplifier now?
It's currently available on Aliexpress:
- 89$ without power supply
- 109$ with a 36v5a power supply
*Tomorrow the sale will start and the price will be $79 and $98 respectively. P.S. I don't know English very well, I'm writing through a translator
The amp is OK. Works without hickups so far. Nothing spectacular but good value IMO.
At that price it's a steal
also available now in a real nice looking blue color
effectively cheap enough for a garage amp
expect something like 50w? real world
i think as people always say... for $100 you cannot source a case, all the components, psu, the board, remote, cables, the board logic... and its delivered
and you know its going to sound like a tpa 3255
i assume good reliability too
You are right, it's even difficult to get a nice DIY case for 100$, I have just ordered D3 on Aliexpress in Blue colour hoping to receive in 10-12 days or so.
Its a TPA3255 amp with DAC + remote in decent looking case.
As to power output, with 36v 5a PSU:
i'm posting this scan of the manual
i'm kind of lazy myself so i often do this so i can spray it up on a 32" screen so its easy to read
its maybe A6 sized so a real pain to read
also the manual poses even more questions that i will have to ask the manufacturer to clarify
enjoy
i could not find such a manual on their site
quick sort of impressions of this after a week or so
i just dropped this into my usual setup where i can change speakers and dacs at will and the best thing i can say about the D3 is that is offers a pretty seamless experience over my other devices... it just works to a higher level of performance than i expected
i'm using mainly my JBL Arena 130s which is a pretty easy drive at 86dB... with the standard 36v 5a psu there's plenty of clear volume
my other test speakers are the Edifier P17 which at at abysmal 77dB is a much harder ask... i tested a big set of Mission floorstanders which are 89db I think and they will fill the room (and the next room too)
BT is great for Qualcomm phones with AptX... for iphones AAC is also good... had no issues with opt. or coax.
USB input...
well it goes 32/384... whatever it sends to the ESS 9023 is another story but it does work as well as you'd expect from a modern dac
there's a CS 8000 series sample rate converter in the mix
on my example i do notice the 3.5mm analog input has a slightly higher noise floor than the digital section... which I was able to get around by increasing the gain on the dac rather than the device itself... this unit is primarily a digital device and so i can excuse the 3.5 being not as dead quiet as the digital section
i hear the subwoofer out is a fixed 80hz... this worked fine with my tester 8" 100w sub with it on flat
BUT since you have no control over your main speakers you would have to pair it with a small set that cuts at 80hz... which the only set i have that does that is the P17s... with the other speakers i have i feel the bass bleed from the main was a bit... much
do i like this device? yeah I do... it surprised me with how competant it is at everything it purports to do
i do not complain that it does not do MQA or DSD because it never said it did and in reality for most as long as it does better than 24/192 then that's good enough and the ALC 4050 does more than that.
operationally i left the unit with the base blue color on the LED display but with brightness down low... the unit does not have display shut off
the remote looks like a generic unit but there's no mention of the remote at all in the manual but its easy enough to work out
the unit is 100% controllable with the display OR the remote which is nice
the unit is a 'one button device'... ie. the vol. ctrl. presses in lightly to change function but a HARD long press for on/off
also the unit never gets hot but admittedly its the start of winter here but i usually never turn anything off
got a new phone today so some test pics
their branded psu + their remote
strangely the box included a type-c cable which was not on the manifest
i wonder if the unit is amenable to firmware updates???
Hello, how to disable auto standby? Amp its goind to stanby when playing music after 20-30 minutes.
