even if a laptop had the ALC 4050 i would put my money on the D3 with the same chipset given its in a non hostile environment rather than one that has a high performance processor, ram modules, lvds screen, ssd, wifi etc. list goes on
Very true.
Sounds different to me though. Some may say better, some worse. Me, I prefer the sound via the D3's DAC.
My system is very modest. More revealing systems may show up the limitations of the budget infrastructure employed by the D3. I'm just satisfied that the D3, in my system, makes me happy.
And thank you. Glad to be aboard.
www.audiosciencereview.com
I am am just looking to get internal pics first before hitting buy button, want make sure that its not like those 30$ board type.
Digital input, internally decoded into analog output by ALC4050.
alc 4050 is fully 32/384
ess9023 is 24/192
you might ask why the ess is there at all when it could be all routed thru to the alc 4050
but... these people are smart... electronics engineers may have a directive from parts supply to do it this way
The power supply of NE5532 is -12V, +12V, which can better utilize the performance of NE5532.I have been using the O-Noorus D3 for a couple of weeks now, so I'm happy to provide a few, preliminary, comments.
For context, my setup is a desktop (nearfield) application running Q Acoustics 2010s and a Wharfedale SW150 sub in a large office. The source is an Amazon Music subscription streamed via a near new Dell Inspiron laptop.
I was using the Fosi Audio BT20A in this modest setup, but was concerned that the internal DAC of the Dell was, perhaps, letting down the side. I was looking at introducing an external DAC, but in my search, stumbled upon the D3. Internal DAC, red case, TPA 3255, LED display, remote control, included PSU, $170AUD - why not?
I have the D3 connected via the USB input. (I tried the 3.5mm (which utilises the Dell's Dac) but preferred the sound signature using the D3's DAC).
In short, I like the D3 a great deal. I think it looks great and love the LCD screen (the main reason I bought it TBH).
The execution of this little amp, from a functionality perspective, is excellent in my opinion. Mine shipped without an instruction manual, but it was very simple to work out how everything works. Very intuitive in my experience.
The LCD screen offers 4 levels of brightness and 9 different colours. The remote control does on/off and mute, and adjusts volume, bass and treble, and input, but not LCD colour or brightness.
The sub out is variable, but sends a full range signal (no low pass filter) to the sub. It continues to send output to the subwoofer even when the unit is off.
The only analogue input is a 3.5mm jack.
I have absolutely no complaints about the sound quality. The QA 2010s are not the last word in refinement and can get a little sharp, but the D3 sounds better to me than the Fosi in the above set up (possibly due to the different inputs (DACs) utilised) particularly in the higher frequencies; less wince inducing. One of my tests is vocals (the spoken voice) on you tube. Some class D amps (including the Fosi) can make you tube vocals sound harsh and brittle. The D3 doesn't (as much). Not perfect, but no worse than my Marantz NR1405.
In my setup, the D3 sounds better, to me, than the Fosi Audio BT20A Pro. Not by a lot, and possibly only because of my Dell's DAC when running the Fosi.
For reference I also run a variety of Tannoy, Monitor Audio and Q Acoustic speakers with Marantz, NAD, Aiyima, Nobsound (Douk Audio) and Fosi Audio amplifiers. None of which could be considered high end, so my impressions of this amplifier should be considered in this context.
i'd agree but its a marketing thingNormally I won't think of what dac is used, but I have never found any realtek that have sounded good... to me at least.
Also don't care much for 24/384 vs 24/192, I personally don't think I can differentiate.
As long as it sounds good, its acceptable.
+1 I feel the same about this. Anyway, your amp, and more so your speakers and your room is gonna make a bigger difference.i have some 24/96 material and very limited 192 material and so why would i need more?
The NJW1194 has up to 4x analog inputs. If you already have it for vol. and bass/treble control, it may be simpler and cheaper to also use it for inputs switching, even if means having 2x DACs.Wondering what’s makes them choose a different DAC chip for USB over ESS which is already part of design.
Why not using same ESS dac as other inputs?
This is a very nice all-in-one amp with quality components. My only complaint is the 3.5mm jack instead of RCA. So, this means we need an adapter or a RCA to 3.5mm jack cable.
Does the digital input via USB go to the same DAC chip as the SPDIF inputs?4 digital inputs(usb, optical, coaxial and BT) routed through a single DAC chip
Now that you mention it. Maybe not. I don't see any relays or switches to change from each source. Probably the ESS Dac is only used by optical and coaxial inputs. Leaving BT and USB to be handled directly the each chip(Realtek and Qualcomm), and then all 3 outputs plus Line In (3.5mm) go into the NWJ1194, and all the switching is done by that chip.Does the digital input via USB go to the same DAC chip as the SPDIF inputs?
If you don’t need DAC then you probably have better options from Aiyima and Fosi, cheaper and with power supply.Now that you mention it. Maybe not. I don't see any relays or switches to change from each source. Probably the ESS Dac is only used by optical and coaxial inputs. Leaving BT and USB to be handled directly the each chip(Realtek and Qualcomm), and then all 3 outputs plus Line In (3.5mm) go into the NWJ1194, and all the switching is done by that chip.
Being honest I'm not interested in those digital inputs. I prefer to use an external DAC. But as a desktop amplifier or an all in one amp should work fine.
Yes, sure. Unless you really want a remote control, digital volume control and a real subwoofer out.If you don’t need DAC then you probably have better options from Aiyima and Fosi, cheaper and with power supply.
Not denying at all, but others amps have aux out which works fine with subs and now sub out amps are coming as well.Yes, sure. Unless you really want a remote control, digital volume control and a real subwoofer out.
its clear this place loves the single input no remote TPA3255s especially with the PSU rolling going on
but this forces you into a two box solution
for some people they want the one box that does it all... the D3 is this box... to me this is a much more novel approach... i like the red color and funny display
you got to evaluate whether this thing suits you...eg. it has a modern BT interface... many people here dont care about that...
and you cant 'psu roll' and so power to this unit will always been pretty low
given the preamp stage will eat some power i'm guessing this does a real 30w at 8 ohms???
