People hi
Generally, a second order filter (-12dB/oct) is used for the high pass filter (most common cases except high-end equipment).
The '
connection' frequencies would be preferable to 60, 80 and 120 Hz depending on the diameter of the speaker of the accompanying speakers; The smaller the speaker, the higher the cutoff will be in order to '
relieve' its reproduction in low frequencies and consequently reduce the level of distortion while allowing louder listening levels (depending on these admissible power capacities, of course).
For professional sound recording with good monitoring speakers equipped with a good-sized driver for the bass reproduction, it is common for engineers to use the crossover frequency of 80 Hz because it allows better '
readability' and '
SQ' of the sound range that will be reproduced.
NB: if you look carefully at Amirm's reviews of the speakers, you will see that the distortion (especially in the bass) increases proportionally with the increase in the listening level expressed in dB SPL at 1m: you will therefore have to judiciously choose the 'connection frequency' for the high-pass filter in order to use the subwoofer to compensate for these defects because it is of course designed to produce bass (and not anything else).
'Physically' and due to the laws of acoustics, a small diameter speaker cannot correctly reproduce 'deep' bass with a few exceptions of certain 'special' creations but which are very poorly distributed and rather (very) expensive...
I said that but pretend I didn't say anything
See you soon...
