O-Noorous D3 Pro + tablet questions
Pierre159
Hello everyone,
I'd like to build a new system based on the upcoming O-Noorous D3 Pro and a tablet as a streamer to provide a large graphical interface (something like 12"). What connection do you recommend I use between the two to achieve excellent sound quality? Will Bluetooth be sufficient? USB-C? HDMI? I haven't purchased the tablet yet. Do you have any recommendations? I'd also like to install equalization correction software on it to have a system more complete
Hello everyone,
Better way would be to add a streamer, even cheaper Arylic or WiiM mini would do. Take optical out from streamer to D3 Pro.
Bluetooth won’t be as good or reliable as WiFi streaming.
If you don’t want to add a streamer then only other better option is USB out from tablet to D3 Pro.
If you stream via Bluetooth and Ldac codec you will get vey good results. You can check ASR measurements of Ldac codec vs SBC here
24bit/96Khz mode will provide great results
